Driving Lights & Central Locking Kit 2002 Rodeo 4x4
Submitted: Monday, Dec 21, 2009 at 11:42
Nugget6
G'day everyone,
Merry Xmas & all the best for the new year.
Just a little advice if I could?
Just purchased a 200 3.0 td rodeo 4x4 d/cab on the weekend.
It needs a good set of
driving lights for me to see in the dark and a remote central locking kit for the wife & kids.
Any suggestions would be appreciated both positive and or negative on both subjects.
I have had IPF lights on my past couple of trucks but feel that there are better ones out there on the market at present for a little less money......
Anyhow,
Thanks in advance,
Andrew.
Reply By: Member - John - Monday, Dec 21, 2009 at 14:52
G'day, have a set of IPF HID, spread and spot beams, 55Watt, awesome lights, not cheap, but I think any of the HID sets will be far better than any of the normal halogen
driving lights. Give your self a chrissy present.......... John
395949
Follow Up By: Nugget6 - Monday, Dec 21, 2009 at 15:39
thanks john, i appreciate your reply.
i was looking at the HID lights from the word go.
definately a chrissy present but its a monopoly as to which set to buy!
thanks anyway.
regards
andrew
664639
Reply By: Member - Kroozer (WA) - Monday, Dec 21, 2009 at 15:28
Definitely there are brighter and lighter spotlights out there.
HID is the way to go if driving at night a bit or if you want the best possible light. For very
bright halogen lights i would go either the Hella Rallye 4000 or the Lightforce 240 Blitz or XGT. These 3 lights are by far the brightest and best lights on the market for under $600 a pair.
Hellas are around $420 a pair on Ebay
Lightforce 240 Blitz about $390 on Ebay
Lightforce XGT $485 on Ebay.
There are also kits on Ebay to convert these lights to HID for around $200-$250 a kit.
IPF is over rated by a long shot in terms of light output. HID IPFs arent even as
bright or spread as much as a Halogen Hella 4000. Lightforce shine the furtherest but dont have very good spread.
395953
Follow Up By: Nugget6 - Monday, Dec 21, 2009 at 15:41
hey kroozer,
thanks for your reply and imput.
"Lightforce 240 Blitz about $390 on Ebay "
these are the ones i was watching on ebay!
they have the ticks so far with the research that i have undertaken.
andrew.
664641
Follow Up By: Member - Timbo - Monday, Dec 21, 2009 at 17:57
Hey Kroozer, that is worth remembering...
I got a set of IPF Xtreme 800XS and was very impressed with the light output (they replaced a set of Hella
Comet 500s or 550s - not sure which).
I was a bit nervous about the metal bodied IPF's and the potential for metal fatigue but I bought them on the ARB salesman's assurances that it wouldn't be a problem. Not long after, I had to have both bodies replaced (thankfully, under warranty) due to metal fatigue. I've still got them but never fitted them again in the fear of the same thing happening.
I think I'll look at a set of Hella Rallye 4000s next time since I had good use out of the cheaper Hella's (only had to replace them due to a rock through the glass) and they didn't shake like IPFs did on corrugations!
I'd never buy Narva again: somehow they managed to incorporate metal fatigue into a plastic body!
664656
Reply By: Member -Tukka (WA) - Monday, Dec 21, 2009 at 16:18
74474
395962
Reply By: Member -Tukka (WA) - Monday, Dec 21, 2009 at 16:20
Lol sorry Nugget, pressing wrong buttons, i was just going to say have a look and thread number 74474 or have you already??
Just thought about it when you called your car a truck. Stupidest argument i have even read on here i think
Back to the subject, i have a set of 240 blitz on the front with the hid kit put through them. They are brilliant.
395963
Follow Up By: Nugget6 - Tuesday, Dec 22, 2009 at 07:37
thanks tukka, your feedback is appreciated.
664701
Reply By: Member - Cantiva Clay (NSW) - Monday, Dec 21, 2009 at 18:34
I had the same light problem and went for a set of Rallye 4000 compacts (1 yr old couple minor scratches) and 'bout a 55w HID kit on ebay $170 (someone sells a retro fit for these lights) and they are blinding. It was a spread + spot but replaced
the spot lens with another spread as its not needed with HID (its a small circle a kilometer away...I'm not joking!). I think the beam shape is a bit odd as the reflector obviously isn't optimised for HID but at a saving of $600 who cares. On country NSW roads there's no problem spotting roo's and related. I also wired each light separately so you can use 1 or 2 and control the amount of light. The only thing with HID's is that they take a bit of warming up but they are good once they are hot also reflective signs tend to blind you!
395973
Follow Up By: Nugget6 - Tuesday, Dec 22, 2009 at 07:40
thanks cantiva clay, good points about the small circle etc.
664702
Reply By: Member - Malcolm (Townsville) - Monday, Dec 21, 2009 at 20:56
Hi Nugget
And a Merry Christmas to you and your family.
After reading the test of 37 different lights in 4WD Action No. 139 IPF 900XS Halogen lights are RRP $474 for a complete kit and were Highly Recommended. Compare this to the IPF 900XS HID which were also Highly Recommended BUT at RRP of $937 EACH light I would like to be able to recycle the GOLD parts to justify the cost.
I recently bought a D-MAX and fitted a set of IPF 900XS (Halogen) both spread beams. I want to see the roos on the sides of the roads not something two kilometres in the distance. Coming back through the Marloboro stretch I really enjoyed these lights. I could see far enough into the distance and also the 20 odd groups of roos/wallabies on the side. One thing I didn't like (closer to suburbia) was the glaring road signs and markings that bounce the light back at you. Actually had to turn these lights off to stop being dazzled.
The most awesome light in the test was KC Hilites from USA at US$990 per light. Pssst! They do have a 23 year warranty.
I suppose it all comes back to budgets and where you will be using them.
Malcolm
395989
Follow Up By: Nugget6 - Tuesday, Dec 22, 2009 at 07:44
hey
malcolm,
thanks for your response.
i will be moving to a place called enngonia in the new year. it's 100klms north of
bourke in nth western nsw. not much out there apart from roo's pigs and lotz of emus. it's good there is not to many road signs too from what im reading!
intresting, thanks anyway, something else for me to think about.
andrew
664703
Reply By: D200Dug- Tuesday, Dec 22, 2009 at 00:02
" One thing I didn't like (closer to suburbia) was the glaring road signs and markings that bounce the light back at you. Actually had to turn these lights off to stop being dazzled. "
This is an increasing annoyance driving at night with high beams on :-(
396008
