CT 18
Submitted: Monday, Dec 21, 2009 at 15:21
Member - Kroozer (WA)
Howdy folks, i am thinking of soaking the underneath of my car with Ct 18 overnight to try and remove some of the red dirt and other crap from underneath. As it has been sold i want it to look half decent.
Googled it a bit and got mixed results from other forums. Some say its harmless now cause it been reformulated, others say its bad stuff and will eat rubber and all sorts. In two minds here, surely it cant be that bad. Will be spraying it on with a 5L garden sprayer and hope to leave overnight. Or should i just leave for an hour or so?
Will also be doing engine bay too.
Should I or Shouldnt I ?
Kroozer
Reply By: Member - John (Vic) - Monday, Dec 21, 2009 at 15:23
I use it all the time, good stuff in my view.
I would just use it as you please.
395952
Reply By: Member - Uncle (NSW) - Monday, Dec 21, 2009 at 15:29
I use it underneath the Patrol when it's really bad. Only leave it on for half an hour or so, but never use it on paint work, it must have some sort of caustic in it and has marked paint on my other vehicles in the past.
cheers unc
395954
Reply By: Member - Rodney B- Monday, Dec 21, 2009 at 15:43
Used it for years with no bad results. If on paintwork don't leave for more than an hour or it will leave streaks (these will wash off) but underneath can leave all night. Hose off with high pressure for best results.
395957
Reply By: Fatso - Monday, Dec 21, 2009 at 16:03
Don't use it straight. Undiluted it lifts the paint on concrete.
395959
Reply By: Member -Dodger - Monday, Dec 21, 2009 at 16:29
Have used it on both our vehicles plus the van. Premixed according to instructions, leave it on overnight and let dry then simply hose off.
I have been using it this way for 10 years without problems.
Just don't use it undiluted. IE. follow instructions.
395964
Reply By: Member - Geoff H (QLD) - Monday, Dec 21, 2009 at 16:42
I use it diluted with good results, but never use high pressure under the vehicle, it pushes
water and grit into the seams of the vehicle causing rust.
You only need a garden hose to clean the gunk off after a good soaking.
Geoff
395965
Reply By: Member - Duane A (WA) - Monday, Dec 21, 2009 at 18:13
Dont use it on your paint work at all it eats the wax out of the paint car wash that you use and will stuff your paint job up. Thats if you are worried about your paint job . Under the vehicle its great stuff.
395970
Reply By: Member - Stephen L (Clare SA) - Monday, Dec 21, 2009 at 18:55
Hi Kroozer
A few varied reports. Have used it for over 17 years and is unreal. It can be used safely on ANY surface, providing you follow the instructions. They recommended a minimum of 10 20 minutes penetrating time, even overnight
Vehicle Care & Protection
For all types of vehicles
Foam on.
CT18
Hose off.
4x4 Action Wash
FEATURES & BENEFITS:
• Australia’s No.1 concen-
trated multi purpose heavy
duty cleaning gel.
• Suitable for all types of
vehicles, bikes, boats,
equipment and exterior of
houses.
• Biodegradable, pH neutral
and inhibits rust and
corrosion.
• ‘Quick Break” laboratory
tested (total separation of
oil and
water).
• Free rinsing and can be left
to dry on the surface.
• Removes the toughest dirt,
grime, oil film, soot and
PART NO.
PACK SIZE
bugs leaving a sparkling
CT18-2L
2 Lt
streak free finish.
TOLL FREE PHONE
Manufactured & Distributed by:
1800 177 989
Applied Australia Pty Ltd
92 Fairbank Road
TOLL FREE FAX
Clayton South VIC 3169
1800 308 556
A very satisfied customer.
All the Best for the Festive Season..
395977
Reply By: Willem - Monday, Dec 21, 2009 at 20:23
Krooozer
Park over a garden sprinkler and let it run all night. Will soak the lot and also a cheaper by far :-)
395986
Follow Up By: Rob! - Tuesday, Dec 22, 2009 at 15:40
It's only cheaper if your (10 000 litres of)
water is free.
664770
Follow Up By: Member - Kroozer (WA) - Tuesday, Dec 22, 2009 at 16:37
Yeah i tried that approach Willem. It did get most off, but still a bit that needs a good scrub or something, but i aint scrubbing. Already got the gear to do it so might give it a go tonight. Hopefully i wake up to a body but no chassis. That would be funny.
664781
Reply By: Chambo - Tuesday, Dec 22, 2009 at 07:54
Willem,
You obviously don't have any
water restrictions where you live lol
Chambo
396025
Follow Up By: Krakka - Tuesday, Dec 22, 2009 at 11:57
Nowhere that I am aware of actually has
water restrictions, only time constraints.
664734
Reply By: fisho64 - Tuesday, Dec 22, 2009 at 09:45
why worry about it if youve already sold it?
396036
Follow Up By: Member - Kroozer (WA) - Tuesday, Dec 22, 2009 at 16:34
Just the kind of guy i am mate. Gotta make him feel good about buying it. At least for a while anyway.
664780
