Tuesday, Dec 22, 2009 at 13:01
macy: if you can get 13 1/3 amps out of a solar panel for a period of one hour then yes, it will be 13 1/3 amphours. if you only get it for two hours it is 26 2/3 amphours.
amps and amphours are two different beasts. one is a measure of current flow ( amps ) and the other is the amount of current flow for a period of time ( amphours ). hence the difference in units.
Mike R: i was explaining the answer to the question that was asked. if you like i can do the same for you with an 18V 80W solar panel or any other combination. Please don't turn a simple electrical question into the physics of how a solar panel works. the fact that the voltage on a solar panel for maximum power transfer varies with the incidence, panel design and various other factors and is typically anywhere from ~17-19V is a lot more detail than required to answer the question asked. a solar panel is almost like a constant current device except for the bit that isn't.
If you like we can start a new thread on the physics of solar panel design, or a thread on typical solar 'rules of thumb'.
My comments for the relationship between power, voltage and current in series and parallel stand regardless of the device providing the power.
664743
