Tyres and Flares for Troopy - Footnotes
Submitted: Wednesday, Dec 23, 2009 at 10:10
Gnomey
G'day Guys
Have my flares on and thought I'd mention some tips and tricks for those seeking less adventure in a similar project.
Got the TJM flares for $500. It took 4 calls before I found a store with them in stock and after I drove there it turned they didn't have the right ones afterall. Duh. Cough. Lucked out at a nearby trailer parts joint that has some TJM stuff.
* If you've got one (70/73/75/78) with the OE sub
tank the correct part no. for the rear is: 261DEXRF68M. That's the RHS one with the scallop to allow the
fuel door to open.
* The fitting instructions are there, but not in the plastic bag with the flares and parts. It's stuffed down the bottom of the carton somewhere. Dig it out because there's a right and wrong way to fit the rubber strip - don't ask how I know this.
* Locktite gel super glue intermittently beaded will hold the strip on. A little extra at the ends and curves and a judicious nick will help the strip follow the tighter bends.
* Practice fitting the strip before applying glue. There's a knack and you'll know how much to glue up at a time. (Let us know if you find out what solvent gets the glue off your fingers easily)
* Some small quick-grip wood clamps are handy to hold the flare in place while fitting.
* I used small tek screws with a wide flat head instead of the pop rivets. Better choice for the front flares which don't have much overlap beyond the lip of the guard. ie small distance between each hole and edge of flare.
YMMV
Mark
Reply By: Member - John (Vic) - Wednesday, Dec 23, 2009 at 10:21
Got any photos??
396163
Follow Up By: Gnomey - Wednesday, Dec 23, 2009 at 10:56
Just took some and then discovered
membership has its privileges - uploads being among them. Happy to email them if you give me an address. (Can't PM either.)
Mark
664882
Follow Up By: Gnomey - Wednesday, Dec 23, 2009 at 10:58
Mark
664883
Follow Up By: Member - Kiwi Kia - Wednesday, Dec 23, 2009 at 11:15
Hi Gnomey, Could you let me see the photos please.
nzrees@yahoo.com
Thanks, KK
664884
