Thursday, Dec 24, 2009 at 10:59
Thanks for your replies, I agree with the idea of using straps. I had looked at a secondhand sub-
tank and was thinking of cutting off the damaged bracket and making up a strap to go under the back end. Unfortunately it went for more than I thought it was worth on ebay.
Further investigation into the OE tanks on the Patrol show they are pressed in two halves and then the halves are joined in a seam around the middle of the
tank, this seam is then bolted directly to the chassis.
Makes me wonder if the theory of the chassis flexing is a myth, and it is just insufficient metal in the long range
tank wall to support the weld or the welds are too small to support the weight.
Looking at the design of long range tanks, they all bolt directly to the chassis too, if one of their brackets was not positioned correctly in manufacture then the load would not be balanced and one of the brackets would take too much load until it fails.
I still think that if I do go long range tanks I would look at mounting it between two rubber blocks.
665028
