Mapmerge for OziExplorer
Submitted: Wednesday, Dec 23, 2009 at 14:57
Mikee5 (Logan QLD)
Hi Guys,
I have scanned and stitched 15 of my paper NT 1:100,000 maps and now I am merging them into a mosaic using Map Merge for OziExplorer. So far so good. The question I have is this:
On the scale for the destination map how many metres per pixels is best, the default is 100. I tried 1 but the laptop looked like it would take a week to do the job so I changed it to 10, I thought this was too quick so I went to 5 which it is doing now - as I am not sure what I am really doing, is there an expert who could tell me if I am on the right track, please.
Reply By: DIO - Wednesday, Dec 23, 2009 at 15:13
Have a look here
LINK
396197
Follow Up By: Mikee5 (Logan QLD) - Wednesday, Dec 23, 2009 at 15:20
Thank you, this is where I downloaded the software and the help file for Map Merge, unfortunately while the help file describes the metres per pixel, it doesn't advise what is best - compared to the discussion about the number of colours where the help file goes into details about 8 vs 32 vs 64 colours. I am hoping someone who has done a merge can give some practical help.
664900
Reply By: The Explorer - Wednesday, Dec 23, 2009 at 16:11
Hello, there is no set value you should use. Obviously the less metres per pixel the better resolution you will have but at the cost of increase file size. However there is no point in making the m/pixel setting less than the original image. A bit of experimentaion maybe required to get the best comprimise between resoltuon and file size (though 15 maps isnt that many so cant see file size being too much of a problem sepending on original scan resolution).
Maybe not 100% relevant as I didnt use mapmerge but the 100K mozaics I have done are as follows
165 maps - resulting file is 10.6m/pixel - 1.1GB (ecw format)
126 maps - resulting file is 11.3m/pixel - 0.89GB (ecw format)
I have another ecw mozaic with about 100 maps (ecw format again) - it is 5m/pixel but only 156mb - mayeb ecw compression higher (?) The map is not as clear as the others I have despite less m/pixels??
Anyway - I would suggest you stay with the same similar m/pixel as the original. You are only doing 15 maps so cant see file size being a problem. Set it to go overnight if need be - a watched kettle never boils!!
396205
Follow Up By: Mikee5 (Logan QLD) - Wednesday, Dec 23, 2009 at 16:21
Thanks Greg,
It is good to know I am on the right track. It is ticking away now @ 5m/pixel. I may re-do at better resolution if I am not happy with the result and, as you say, leave it overnight. These maps are old and have annotations on them so are
well worth preserving.
Mike.
664909
Follow Up By: Mikee5 (Logan QLD) - Thursday, Dec 24, 2009 at 09:29
Thanks for the help. The computer took 6 hours to do the merge and it has worked, the result is pretty good. I might re-do it over the break with different settings to see the difference. For a first go just reading instructions and help files I sometimes surprise myself :)
Mike
665021
Reply By: Member - Andrew (QLD) - Wednesday, Dec 23, 2009 at 16:44
Another left-field thought Mike is to look at the seamless mapping feature released in the latest development version....the ability to simulate seamless mapping might fix the problem of losing detail and save some time etc.
quick link:
http://www.oziexplorer3.com/dev/development_version.html
Just a thought, merry christmas :)
Andrew
396209
Mike
665020
Reply By: Charlie - Thursday, Dec 24, 2009 at 06:56
Its probably best to match your original resolution, figure out the width of the map in meters and divide by the pixel width shown in the "check calibration of map" . I'm going to take a wild guess and say the figure is between ten and twenty five.
396261
Follow Up By: Member - Andrew (QLD) - Thursday, Dec 24, 2009 at 07:16
...or just push the "info" icon ;)
Andrew
664999
Follow Up By: The Explorer - Thursday, Dec 24, 2009 at 08:52
m/Pixels of the original is shown when you load the map into into mapmerge. No pre-planning required.
665011
