4WD light
Submitted: Wednesday, Dec 23, 2009 at 22:37
ThreadID: 74609 Views:3307 Replies:5 FollowUps:18
Can anyone tell me what may be wrong if the light on my dashboard doesn't light up anymore when I put it into 4WD?
Thank you.
Ros
Reply By: Member - Mike DID - Wednesday, Dec 23, 2009 at 22:41
The bulb has blown ?
AnswerID: 396243
Reply By: Member - John (Vic) - Wednesday, Dec 23, 2009 at 22:42
Wire fell off the back.
Bulb gone.
Selector switch stuffed.
Wire damaged.
Not engaging 4wd.
Hows that for a start?
A bit more info like make, model and year of vehicle could help??
AnswerID: 396244
Follow Up By: your the pussy mate - Wednesday, Dec 23, 2009 at 23:20
it is a 1996 toyota prado, it engages in $WD but the light doesn't come on anymore?
It may be difficult to get behind the dash to check a bulb?
Ta
Ros
FollowupID: 664976
Follow Up By: Member - John (Vic) - Wednesday, Dec 23, 2009 at 23:50
OK so that only leaves
Bulb gone.
Wire damaged.
FollowupID: 664980
Reply By: Bonz (Vic) - Wednesday, Dec 23, 2009 at 22:48
Nice user name, do you think you should change it?
AnswerID: 396245
Follow Up By: Member - John (Vic) - Wednesday, Dec 23, 2009 at 22:50
Thought the same thing but you know me, to polite to comment :-)
FollowupID: 664970
Follow Up By: Bonz (Vic) - Wednesday, Dec 23, 2009 at 22:51
Someone had to say something, might refer it to the moderators
FollowupID: 664971
Follow Up By: Richard Kovac - Wednesday, Dec 23, 2009 at 23:08
FollowupID: 664974
Follow Up By: your the pussy mate - Wednesday, Dec 23, 2009 at 23:19
aaawww come on it's not meant to be offensive, lighten up
FollowupID: 664975
Follow Up By: RedJK - Wednesday, Dec 23, 2009 at 23:32
This post has been read by the moderation team and has been moderated due to a breach of The Friday Funny Rule .
Forum Moderation Team
FollowupID: 664977
Follow Up By: Shaker - Wednesday, Dec 23, 2009 at 23:42
QUOTE: "Nothing wrong with his username....."
Yes there is ....
Should be ..... you're the pussy mate!
FollowupID: 664978
Follow Up By: Member - John (Vic) - Wednesday, Dec 23, 2009 at 23:48
Thanks Shaker I always get "your" and "you're" mixed up also. :-)
FollowupID: 664979
Follow Up By: Alloy c/t - Thursday, Dec 24, 2009 at 09:17
School holidays again ,
FollowupID: 665018
Follow Up By: Who was that again? (Vic) - Thursday, Dec 24, 2009 at 12:18
Shaker, my be you have the poster's gender wrong. Signed Ros, not Ross above.
FollowupID: 665030
Follow Up By: Shaker - Thursday, Dec 24, 2009 at 13:41
How is it gender related?
FollowupID: 665040
Follow Up By: fisho64 - Thursday, Dec 24, 2009 at 19:02
thumbs up for the user name I reckon-a little levity is welcome!
FollowupID: 665072
Follow Up By: Richard Kovac - Thursday, Dec 24, 2009 at 20:37
FollowupID: 665078
Follow Up By: Member - John (Vic) - Thursday, Dec 24, 2009 at 21:09
I getting a bit worried about you Richard :-)
All the best to Robyn and yourself for Chrissy, have fun and stay safe.
FollowupID: 665086
Follow Up By: Richard Kovac - Thursday, Dec 24, 2009 at 21:27
And all the best to all the EO members and guests...
From Both of us..
R & R Kovac
FollowupID: 665090
Reply By: Member - Rob S (NSW) - Thursday, Dec 24, 2009 at 08:00
Hey Ros
As every one else said.
But more than likely the selector switch on the gear box.
Check the wires or plug on the switch, they get corroded .
You could try and bridge out the wires at the switch located some were on the transfer case turn on the ignition to prove it's not the dash light.
As with most 4wd doesn't get used very often and The contacts don't contact very well.
Sometimes giving the 4wd lever a work out will solve the problem.
Ps , I wish i had your user name, LOL
I only ever made one mistake
AnswerID: 396265
Reply By: Graham Watson - Thursday, Dec 24, 2009 at 08:17
From memory the light should come on along with all the other emergency lights when you first start the car. That will ell you if the problem is with a blown bulb or a possible wiring problem.
Graham
Graham Watson
AnswerID: 396268
Follow Up By: Shaker - Thursday, Dec 24, 2009 at 08:56
Good call!
FollowupID: 665013
Follow Up By: Member - Rob S (NSW) - Friday, Dec 25, 2009 at 15:12
The idiot light(warning light) for 4wd on my 80 series dosn't illuminate with ignition on.
Only when the lever is engaged.
FollowupID: 665120
