Switch Mode Multi-Stage Smart Battery Chargers
Submitted: Saturday, Dec 26, 2009 at 19:35
Richard Kovac
What am I doing wrong?
Had to replace a blown "Power Saver" BC-012-15A because it was damaged (I think) due to a Lighting strike, this was back in 11/09. they told me the "Power Saver" BC-012-15A was not made anymore and to buy a ELECTRO BC-1215, so I did hooked it up and all good, till I just arrived in
Bruce Rock where the Caravan is, a 11' Supreme and the new charger is dead.
checked it out and found the T3.15A fuse AC input blown, I removed the charger from the small hole they put it in to check it out.
Fitted another fuse, this time just a 3A one put on all the PPE and turned on 240 VAC popped the fuse straight away....
now it's been 3 weeks since we have been up, and not sure about the weather, but
Bruce Rock is 250 km east of
Perth in the wheat belt today it's around 38 deg c no rain but the
water tank tells us we had some wet weather.
We have lost no other electrical appliances (last time we lost a TV, VCR, answering machine and two Battery chargers).
So is there something I'm doing wrong (have had van for 4 odd years now and this is first trouble) this time I fitted a surge protector at the AC outlet (a cheapie) is anyone else had the same problems?
If so or not has anyone got any suggestion on how to fix it?
All the charger has to charge is a Fullriver DC100-12B battery it has 12.1 volts in it at the moment, I will have to get a new charge this week $235.00 and fit it before I losse the battery also..
Richard
Reply By: Mandrake's Solar Power- Saturday, Dec 26, 2009 at 20:26
You could always go solar ;)
Rgds
Mandrake
396466
Follow Up By: Richard Kovac - Saturday, Dec 26, 2009 at 20:47
careful you might get Modded.. :-)
The van is solar ready but no panels, I use a 11 watt panel to keep aux battery topped up in the Troopy, so I know it works, but I should be able to have 240 volt if only a back up.
I just plugged in a Swallow AC/DC charger into the Vans DC circuit and it says there is a problem, but should have blown the DC fuse, me thinks, anyway beer O clock, heading off down the club to drown my sorrows
Richard
665220
Follow Up By: Richard Kovac - Sunday, Dec 27, 2009 at 01:51
Mandrake
Van is also in a shed..
Richard
Real names should be compulsory signature
665241
Follow Up By: Mandrake's Solar Power- Sunday, Dec 27, 2009 at 09:18
My electrical and electronic knowledge base is still in its infancy but --
Obviously its a short-circuit problem .. could it be crossed polarity somewhere ?
Or "chewed" wires touching inside the van ? Faulty switch that is fused on ?
You're going to have fun finding it ...
Friend of
mine has a lamp 12v and small battery that he connects to the +ve and -ve contacts of a socket - If the lamp lights up then he knows he has a short-circuit - disconnect from 240v first though !!
I'm sure you can buy one that plugs into the 240v socket - has three LEDS on it
Steve
665252
Follow Up By: RV Powerstream P/L - Sunday, Dec 27, 2009 at 11:06
Steve
So your parents didnt punish you by calling you Mandrake its really Steve.
Ian
665262
Follow Up By: RV Powerstream P/L - Sunday, Dec 27, 2009 at 11:12
Richard
Steve didnt put "MY" in front of solar so he is safe (I hope)ha ha.
I was going to put LOL which I thought means lots of laughter but I used it last week to a chap and he got into me saying whats this Lots of Love bit mate so I think I will just ha ha in future.
Ian
665263
Follow Up By: Mandrake's Solar Power- Sunday, Dec 27, 2009 at 11:24
LOL in forumspeak is supposed to be "Laughing out Load " which them progresses to "ROFL" then "ROFLMAO" ....
Mandrake was my comic book hero from when I was a kid AND wife's name is Nadia which is very close to Mandrake's wife Nada ...
Funny how these things follow you through life ... Is it coincidence or destiny ?
Rgds
Steve
665265
Follow Up By: Richard Kovac - Sunday, Dec 27, 2009 at 13:38
Steve Thanks
The 12 VDC should be ok as it is not triping the circut braker and everything is working fine. I will take the van for a run today and charge up the battery, and then have a play and see if I can find something wrong.
As I know when I take the Charger back for warranty they will try and knock it back, so have to go in with info.
Richard
665280
Reply By: Member - John and Val - Sunday, Dec 27, 2009 at 09:40
Richard - a trap with 3.15A mains fuses - they are usually slowblow. These allow big surge currents for a short time without blowing, necessary to handle the starting surge presented by a switchmode device.
You may
well have a defective charger (especially if it is rated 110 - 240 volts and the voltage selector circuit has died, which is not unlikely if there has been a lightning zap nearby ), but first I'd replace the 3.15A fuse with a slowblow one.
HTH
| J and V
- Albert Einstein
396508
Follow Up By: Richard Kovac - Sunday, Dec 27, 2009 at 13:33
I will try that as the fuse I had was a fast blow type, do you know why they but the "T' in front of the rating on the paper work?
Richard
665279
Follow Up By: Member - John and Val - Sunday, Dec 27, 2009 at 16:09
Richard - Type T fuses are slowblow, type F are fastblow. (Why type T?? I think it refers to T for thermal lag, but others may know much better.)
Further to the cause of blowing - if the charger is rated 110 to 240V, it will be capable of switching between these voltages, automatically selecting the right one. This automatic switching action is very susceptible to lightning or other spikes on the mains and if it dies, will stay as if set for 110V. When you apply 240V, there's a huge inrush current that will take out the fuse, usually before doing other damage. For use on only 240V (rather than 110 and 240V), the auto changeover (a big IC) can simply be removed. This is a fairly common fix for any switchmode supply.
HTH
| J and V
- Albert Einstein
665304
Follow Up By: Richard Kovac - Sunday, Dec 27, 2009 at 19:31
Thanks John
The charger is
BC-1215 and is rated for 180~260V 50Hz~ .
I tried another fuse standard type and it blow as
well all LED's light up then flicker and turn off, the charger is not connected to anything so no output.
I have taken the van for a 1.5 hour run and the battery is now at 88% hooked up the Christies charger (after striping the Carbie and cleaning a blocked jet,, darn un-leaded
fuel) and charged the battery to 105%, left to settle now 95% and I picked up a Arlec trickle charger in Merredin and will leave it on until I find out why it is blowing the chargers, I will get a Belkin serge protector this time and hope it saves it, I have only one 15 amp outlet in the shed.
Richard
665324
Reply By: Richard Kovac - Monday, Dec 28, 2009 at 23:01
Back in
Perth now.
Tomorrow I will take the charger back to where I got it from and see what they say.. Got the Battery back up to 100% charge with the Arlec charger over night, but did not leave it on by there advice ( you will damage your battery if left on charge).
Ever way I will get a better surge protector and plug it in before new charger, pain in the but really, has anyone out there had any problems with the same thing?
Might have a look at a Ctek as a back up for
Bruce Rock, as it's only a small town with limited shopping.
Richard
396705
Reply By: Richard Kovac - Wednesday, Dec 30, 2009 at 18:29
Small update, Today I took the old damaged charger back to the very nice people that sold it to me (did I say Very Nice People) and they replaced it free of charge, with very little questions asked, so I could not answer any.
I then went off to DSE and got me a Belkin Essential Series Surge Cube + $40,000 Warranty (we will see about that :) so as to try and protect the charger from the outside world (lighting or whatever).
Got a DSE one also $3.00 cheaper will take bigger surge Joules and amps but will pay out less :(
I hope this works, other wise it will be solar ..
Richard
396983
Reply By: R&J Batteries - Wednesday, Jan 27, 2010 at 15:22
Reply By: R&J Batteries - Wednesday, Jan 27, 2010 at 15:23
You might want to read page 28 here first;
ESV newsletter
401313
