Nissan Civilian Bus Convesion
Submitted: Sunday, Dec 27, 2009 at 05:04
going fishen
Hi, I have a Nissan Civilian bus converted into a motor home, ever since I have have had it, I can not get the exhaust brakes working what ever I have tried everything seams OK, but nothing It has power to the solenoid & vacuum the relay seams to be working ,there are not many mechanics around that seem to interested , any suggestions would be appreciated, it is a 4.2 Nissan td42 motor. Thanks Charlie
Reply By: Ozhumvee - Sunday, Dec 27, 2009 at 07:27
Don't know whether the Nissan is the same but on the Toyota's there is a switch either on the dash or the wiper stalk to turn it on or off. It is activated by a switch on the accelerator pedal which in turn activates the solenoid etc.
Does the actuator work when you liftoff the go pedal? does the actual butterfly operate freely in the exhaust?
Usually it is a mechanical problem rather than electrical, most common is the butterfly jamming due to exhaust buildup in the pipe.
396489
Reply By: going fishen - Sunday, Dec 27, 2009 at 10:35
Thanks Peter, for your reply but I have cheeked that, they have a separate lever on the opposite side of the blinkers which seams to be working OK, the butterfly is working but the Spring seams to be real strong one would think it would lose it's pressure over time from heat but it certainly hasn't could be the problem but who knows I might have to look in this area it has 30 psi of vacuum which should be enough ? Thanks Charlie.
396514
Follow Up By: pop2jocem - Sunday, Dec 27, 2009 at 17:49
I agree with Peter, what I have found is that the exhaust brake can be left turned off for long periods and the butterfly valve will seize fully or partially and the normal operating vacuum 15psi at best at sea level will not shift it or only partially.
Pop
665315
Reply By: balko - Sunday, Dec 27, 2009 at 12:31
I know it sounds stupid but make sure the idle knob is turned down. Ive done it myself took me 20 min to work out what was wrong with it Cheers Tony
396526
Reply By: going fishen - Sunday, Dec 27, 2009 at 13:33
Thanks Tony, no the idle is spot on, I have checked every think the micro switchers are working it is just some thing, when it stops raining I will go & pull the butterfly box off it again & start from there, Thanks Charlie.
396532
Reply By: going fishen - Sunday, Dec 27, 2009 at 19:31
Thanks Pop, I will check it out any idea what vacuum pressure it should have at the
valve ? Thanks Charlie.
396556
Follow Up By: going fishen - Thursday, Dec 31, 2009 at 06:28
well I found the problem, the Diaphragm in the the booster is RS now starts a bigger problem trying to find & buy one, it comes as a full unit but a yet I have been unsuccessful trying to put my hands on one, any ideas would be much appreciated, Thanks Charlie.
665776
