Duo Yellow/White 12V Lights
Submitted: Monday, Dec 28, 2009 at 11:51
ThreadID: 74688 Views:2556 Replies:1 FollowUps:1
I am looking at buying some of these from the Shop, But not sure whether to get one 90cm to mount inside doors on the roof lining or two 50cm to mount on each of the barn doors, I was just wondering which way would give more usable light to the back & into the draws when open. Has anyone else with a GU or a wagon with Barn doors used these lights ?
Cheers Dave..
GU RULES!!
Reply By: Member - steve. B... (NSW) - Monday, Dec 28, 2009 at 14:45
Hi Dave. I bought 2 x 90cm from the shop and the were money well spent. I use mine under the awning. Great for keeping the insect away. Only down side is the wiring. very fiddly when connecting to the switch. Very thin wires, best result is to solder them. I take it that you are putting them in your wagon.
Fitting is also a bind, as there are only two small tabs at either end of the light strip. They would not last long on the Barn Doors. Also would of been great if they were Solar. Cheers Steve. B...
AnswerID: 396631
Follow Up By: Dave(NSW) - Monday, Dec 28, 2009 at 17:53
Thank's Steve,
Yeah the barn doors need to be shut pretty hard to close properly so may be better just inside the doors on the roof lining.May be two smaller ones would be better or can you put a saddle in the middle of the longer ones to make them more stable?
Cheers Dave..
GU RULES!!
FollowupID: 665410
