100 Series Auto Dipstick
Submitted: Monday, Dec 28, 2009 at 15:12
Tony @ Naomi
Hi this might be a stupid question, but have just bought a second hand cruiser, and I am unable to find the dip stick to check the auto fluid is there one and if so where is it located.
Thanks, Tony
Reply By: OREJAP - Monday, Dec 28, 2009 at 15:17
I don't think there is one. It's a sealed system. Consult your "Owner's" manual or ask a Tojo dealer. The new Pajero is the same I cannot think of the name of the auto system but there is no more checking auto fluid in modern day cars however the Patrol still has that system.
396637
Follow Up By: Member - Graham H (QLD) - Monday, Dec 28, 2009 at 15:38
On
mine there is a red plug in the side that you check the level
I you can feel the fluid its OK
665398
Follow Up By: fisho64 - Tuesday, Dec 29, 2009 at 10:23
not so sure its that simple. The procedure for refilling/topping up after a change is quite complex due to tranny temp and where the fluid is, as the torque converter holds quite a bit.
Basically if there is no leaks obvious, it will be fine-it cant go anywhere else. Toyota specifies that the fluid not be changed unless it has over heated.
Check LCOOL website for details on the fluid replacement procedure.
665476
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 29, 2009 at 10:40
Yes there is a correct procedure.
Something like getting it hot running it thru all the gears and turn it off and check the level.
There are fluid capacities listed in the Handbook.
665480
Follow Up By: fisho64 - Tuesday, Dec 29, 2009 at 10:45
the fluid capacities are only a guideline, not the exact amount to ad and leave it at that.
Mainly cos when its drained it varies greatly how much comes out. Applies to any machinery especially autos though as a large proportion is in the cooler and TC and doesnt just drop out when drain plug is removed.
665484
Reply By: Member - Kevin B1 (WA) - Monday, Dec 28, 2009 at 15:41
They don't have a dipstick, there is a filler/level plug on the right hand side of the gearbox.
396638
Follow Up By: fisho64 - Tuesday, Dec 29, 2009 at 10:22
665475
Follow Up By: fisho64 - Tuesday, Dec 29, 2009 at 10:24
sorry should have posted above under Grahams followup!
665477
Reply By: Member - Andrew (WA) - Monday, Dec 28, 2009 at 19:42
Pre 2003 or 04 they had a dip stick...after that they became a sealed unit. Obviously you have a newer one.
396680
Reply By: fisho64 - Tuesday, Dec 29, 2009 at 10:28
Assuming you are talking about the A750F (5 speed) they have a pretty good reliability record. Havent heard of a failure yet myself and a mate that owns one and has a 4WD workshop hasnt seen a failure.
Mine has 200K on it and is crisp and smooth still-never had a fluid change. Thinking of giving it a birthday though, even though Toyota dont list it as a service.
Interested to hear from anyone on here that HAS had a problem with one and what occurred?
396750
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 29, 2009 at 10:37
Havent had a problem yet but had a service last week and the auto oil looks a
bit grubby and maybe a little burnt. Mechanic suggested it needs changing.
Not surprising after being fully loaded and pulling a rig totally 6100kg around for 44,000k over 12 months.
Getting oil changed next week.
665479
Follow Up By: fisho64 - Tuesday, Dec 29, 2009 at 10:47
can you let me know how much they charge you for it? Is Toyota doing it?
And how many K's has it got on it?
665486
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 29, 2009 at 11:09
Its done 132,000 of which the last 44,000 has been mostly towing the van
is getting done at an Auto place at Osullivans Beach Rd
Adelaide on Jan 12th
Est price 200+ depending how much oil is used to flush it out.
I didnt actually get to sniff the oil only went on what the mech said.
Am going to put an oil temp gauge on it as
well while we are working on it.
Will post results..
665494
