7 pin plug auxilliary wire to run van fridge while driving?
Submitted: Monday, Dec 28, 2009 at 17:46
Con_Qld
Have taken delivery of a caravan with a 225 litre 3 way dometic fridge/freezer. I was told my 7 pin plug did not have an auxilliary wire attached so I could not run the 12 volts fridge while driving. And the anderson plug was to charge the battery while driving. Given that the fridge would draw high amps, is it a good idea to have an auxilliary wire attached to the 7 pin?..would it burn out the 7 pin plug?
I will be asking the manufacturer to clarify the electrical set up....but am a bit confused...any information to assist in understanding will be greatly appreciated.
Many thanks
Reply By: Notso - Monday, Dec 28, 2009 at 18:13
Short answer is yes the 7 pin plug pins aren't big enough to carry the amps your fridge will pull.
If you are using an anderson plug you can use it to supply your fridge providing your wiring is of a suitable size to carry the additional load imposed by the fridge.
Get some good advice from a 12 volt specialist before you do anything, most van manufacturers wire the 12 volt fridge supply to the 7 pin connectors, but they all overheat the pins when running the fridge.
396651
Reply By: Alloy c/t - Monday, Dec 28, 2009 at 18:17
By rights your anderson plug charges the c/van battery and your fridge runs off that battery does it not ?? Ergo just remember to unplug the anderson when stopped for any lenghth of time with motor switched off unless you have a dual battery cutout already installed.
396655
Reply By: olcoolone - Monday, Dec 28, 2009 at 18:36
Most 7 pin trailer plug and sockets are rated at 20amps constant load over all circuits so you could get away with it but you would be right on the limit and as said before you would properly melt the plug and socket.
You could change it over to a flat 12 pin socket and plug that has a higher current rating.
The ideal way would be through an 175amp Anderson plug and socket and a RedArc dual battery isolator connected inline with the fridge.
When your engine stops running the battery isolator will detect a voltage drop at 12.7 volts and disconnect the fridge.
If you have a battery in the caravan you can Tee of before the battery isolator (for the fridge) and charge the caravan battery without the fridge drawing from the battery.
It's also advisable to have a second battery isolator mounted to you vehicle that isolate the caravan from the vehicle.
And don't forget the fuses.
396664
Reply By: Gunna Do - Monday, Dec 28, 2009 at 18:47
Check the wiring running to your anderson plug through to your caravan battery is heavy enough for the load of the fridge, if so leave the fridge in the van connected to the battery and charge the battery and run the fridge via the anderson plug.
I can't see any need for extra wiring, so long as the original anderson plug is wired up with heavy enough wiring, as
well as the wiring running from the anderson plug to the battery in the van being heavy enough.
396669
Reply By: Member - John and Val - Monday, Dec 28, 2009 at 19:00
Con,
I have 2 heavy pairs of cables running from the front of the vehicle to the trailer. At the front, both of the positive lines are switched (independently) by 30A relays so that power is fed from the front to the trailer when the engine is running. I use Anderson plugs to connect between Troopy and trailer.
Why so many cables? One pair to charge the trailer battery, one pair to run the 3 way fridge. By keeping these independent, the high current drawn continuously by the fridge doesn't drop the battery charging voltage. (Even a fraction of a volt loss can substantially reduce the charging current.)
Why independent switching? To avoid the situation where the fridge would run off the trailer battery if the two positives were connected together.
This works
well. I'd particularly recommend using solid connectors (Anderson) rather than relying on the 7 pin trailer connection. The earth return especially will be heavily loaded if it is called on to carry a few amps for lights, 10 or 12 amps for the fridge, maybe more than that to charge the battery.
HTH
| J and V
- Albert Einstein
396672
Follow Up By: Con_Qld - Tuesday, Dec 29, 2009 at 00:57
Thank you for your comments. I must add that I have two 100amp deep cycle batteries plus two 80 watt solar panels...and I thought that it would be enough to run the fridge off the batteries, but the fridge would not run off the batteries (the electrical design must have been to not run directly off the batteries) but to run off 240 volts and gas when stationary.
It appears that the female part of the 7 pin connection on the caravan side is design to carry power from the car while travelling and the anderson plug is there to directly charge the batteries....so it seems that there must be some electrical converter/relay box in the caravan that converts the voltage from the 7 pin connection to allow the fridge to operate without burning the 7 pin plug & socket??....All this is doing my head in....and now I will try to find an auto electrician at
Southport to change the wirings as you have suggested....many Thanks again for everyones contribution...
665454
Follow Up By: Member - John and Val - Tuesday, Dec 29, 2009 at 07:07
Con,
The fridge draws 10-12 amps continuously when running on 12 volts. This is a serious load for your batteries, which would be dead flat in less than 24 hours.
I would guess that the battery charging and fridge are at present being fed current from the vehicle through a single wire, and the fridge is disconnected by a motion sensitive switch while the van is stationary. This arrangement is not uncommon, but not ideal.
Good luck with it.
| J and V
- Albert Einstein
665459
Follow Up By: Dunedigger - Tuesday, Dec 29, 2009 at 08:25
John and Val are on the money regarding 2 pair of cabling. The battery will never be fully charged if it ALSO has the fridge drawing currant at the same time
665462
Reply By: Member - Rod N (QLD) - Monday, Dec 28, 2009 at 20:19
You can also use a motion sensitive 'Fridge Switch' to isolate the fridge while the vehicle is stopped.
Rod
396692
Reply By: oldtrack123 - Monday, Dec 28, 2009 at 23:32
Hi Con
Take john & val's advise ,wire it seperately Say 6 b& cable POS & neg, back to the tug battery with an ignition controlled relay or voltage sensitive relay in the pos lead &also fused @ battery
/If you wire it of the van battery unless you use quite large cables pos &neg right thru from tug bat to van bat ,the van bat will be very unlikely to get a decent chargei
396707
Reply By: pjk - Tuesday, Dec 29, 2009 at 07:50
I have 12 pin plug and the fridge and van battery run though that with the ingnition on but are cut of once the engine is turned off.If stopped for a while just turn the gas on and light the fridge yours PK
396726
Reply By: ozjohn0 - Tuesday, Dec 29, 2009 at 10:00
An Anderson plug is not required for the auxiliary cable.
A Round 7 Pin Plug or Flat 12 Pin Plug plug will do the job as the Auxiliary cable pin is heavy Duty and will handle 20amps easily. The fridge will pull around 11amps. The cable size to the plug should be around 6B&S.
7 pin flat plugs won't do the job as the pins are to small and the auxiliary one will eventually burn out.
ozjohn.
396742
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 29, 2009 at 10:09
A Large round 7 pin would possibly but a small one is no better than a flat 7pin
An Anderson plug is still the best option.
665473
Reply By: Maîneÿ . . .- Tuesday, Dec 29, 2009 at 11:14
Con,
You say: -> "and the anderson plug was to **charge the battery** while driving"
You obviously have a battery where the fridge is,
so direct wire the fridge to this battery via a "smart solenoid" and decent fuse and you will have NO hassles.
Maîneÿ . . .
396758
