PROTECTIVE COVERS FOR FRIDGES - INSULATION
Submitted: Monday, Dec 28, 2009 at 18:07
Member - DickyBeach
For the last 10 years or so my 60L Engel has "worn" a padded protective canvas cover, but these days the fridge lives permanently in the back of the Cruiser where the risk of scratches etc is minimal.
I'm considering doing away with the canvas cover but before doing so would ask if anyone knows whether the cover is helpful for insulation (when permanently located in the back of the LC).
Dicky
Reply By: Member - ross m (WA) - Monday, Dec 28, 2009 at 18:13
It keeps the sun off which must lower the power consumption.
Any extra layer must work as insulation.
396650
Reply By: olcoolone - Monday, Dec 28, 2009 at 18:18
I can only tell you about our Waeco.
With the cover not on in 40deg heat the top of the fridge is ambient temp and when the cover is fitted, you can put your hand underneath it and it feels cold meaning that heat is escaping from the fridge insulation into the ambient temp and the cover helps stop some of it making the fridge more efficient.
I would expect this to be greater with an older Engel as the insulation is not as good as the Waeco's.
If the fridge can keep the temp inside it will work more efficiency, use less power and maybe last a bit longer.
Plus it stops the fridge getting damaged.
Unless space is at a premium I would keep the cover.
396656
Reply By: Member - Duncs - Monday, Dec 28, 2009 at 18:21
I have spoken to two different fridge mechanics about this.
They both said the same thing. The fridge will work best when it is shaded from direct sunlight but it must have room for air to move around it.
Both recommended a clearance of about 50mm on all sides of the fridge is best. In most vehicle installations that is not possible but at the very least their should be 50mm clearance around the vents in the fridge cabinet.
Duncs
396657
Reply By: DesF - Monday, Dec 28, 2009 at 19:17
Hi, Certainly makes a difference having the cover on, I have a Engle 29ltr 1995 model with a non genuine padded cover and on one trip I was short of room so I took the cover off to save some space , but found the Fridge was running longer without it, also it still looks like new ,
definitely a vote for the cover,
Cheers Des.
396674
Reply By: Member - DickyBeach - Monday, Dec 28, 2009 at 19:47
Thanks everyone, I'll keep the cover on.
396683
