Tibooburra to Innamincka
Submitted: Tuesday, Dec 29, 2009 at 15:12
ThreadID: 74719 Views:6216 Replies:6 FollowUps:6
Hi all
I'm planning a trip next Winter to the Corner Country. One sector will be Tibooburra to Innamincka via the Dig Tree. My GPS mapping software tells me the 290 km from Tibooburra to the Dig Tree will take 6 hrs 38 mins, and the 75 km from the Dig Tree to Innamincka will take 1 hr 52 mins. Can anyone with recent experience of these tracks suggest more realistic travel times for these two trips?
Bruce M
Reply By: Member - Fred B (NT) - Tuesday, Dec 29, 2009 at 15:22
See Dig Tree Circuit trek and other treks to get more info.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 396792
Reply By: Mick O - Tuesday, Dec 29, 2009 at 15:23
Will really depend on the condition of the roads. The Strez (Strz for the purists LOL) can get a bit corrugated after the high traffic periods like school Holidays so many opt for the Bore Track as an alternative from Innamincka to Cameron's Corner (Via Bollards Lagoon Station).
The road out to Nappa Merri is in good condition but the 11 or so Km into Bullah Bullah Waterhole & the Dig Tree can be very rough (rocky and corrugated).
I'd say that 6:38 is a high estimate based on 50 kph. The Strz will generally allow a bit more speed than that but again will be determined by the conditions at the time you travel.
Camerons Corner to the Dig Tree
Check the trek notes here on the site as they are always a great source of info for the areas and routes you intend taking.
Cheers Mick.
P.S. If you're camping at the Dig Tree, take some firewood in with you. It's pretty scarce at the camping area.
AnswerID: 396793
Reply By: Member - Duncs - Tuesday, Dec 29, 2009 at 16:03
Bruce,
If you went from Tib to Innamincka via the Bore Track through Bollards Lagoon it should take around about 4 hours, more or less depending on how you travel. I have been on the bore track a few times and it doesn't vary much in condition or travelling time. The thing that has made the biggest difference for me has been how I was feeling or was I in a hurry.
The road north out of Tib to Nappa Merrie is not too bad but probably not as quick as the Bore Track. Tib to the border is pretty good gravel, north of the border there is a bit of dune country but you can still travel reasonably quickly. Further north it becomes a bit more of a track and you will slow down. The track is more windy and undulating up and down through gullies then back up onto the plateau before you get to the Innamincka - Nappa Merrie road which is quite good but can be corrugated.
I reckon it would take a little over 4 hours but I have never really timed it.
I have travelled from Innamincka to Broken Hill in a day using both routes. The Bore Track is definitely the quickest.
There is a nice swimming hole under the Bourke and Wills Bridge which has seriously impacted on my travel time in the past.
Duncs
AnswerID: 396799
Follow Up By: Member - Duncs - Tuesday, Dec 29, 2009 at 16:09
I just looked at Google Maps and it reckons it will take 8 hours 35 min from Tib to Nappa Merrie via Santos.
That is the way I would go and I would halve that travelling time.
Duncs
FollowupID: 665528
Follow Up By: Luke2 - Friday, Jan 01, 2010 at 12:02
came back down (southwards) along the strzlecki in October and it was 100ks most of the way - excellent condition although of course that can change pretty fast. just a query on the bore track north from bollards to innamincka - i did it in early 2006 and it was very slow, lots of sand and definately much slower than the strzlecki back then. sounds like it might have improved?
FollowupID: 665976
Follow Up By: Member - Duncs - Friday, Jan 01, 2010 at 16:39
Luke
I have never done the top end of the Strz, Merty Merty to Innamincka. I last did the Bore track in October 2006.
I was towing my Trak Shak camper and had a boat on top of that. That day we travelled from Broken Hill to Innamincka with a pretty leisurely stop in Tib for lunch. At the end of that trip we came home via Santos and Warri Gate to Tib.
I previously travelled south on the Bore Track in October 2004, from Innamincka to BH, again in the day. That was at the end of our centre and Simpson trip.
I found the Bore track a pleasure to drive both times. I travelled it with different companions, each of them found the track fun to drive.
In 2006 I had one of those days when I just fell into a groove and I could pick lines through corners and settle instantly on them. I was picking the smooth run through the sand and the easy way around bog-holes really early it just seemed easy. That was a bit less the case in 2004 but it was still fun. Yeah there was lots of sand but it did not slow me down much. And it is a fair bit shorter than going via the Strz.
It was a bit the same coming down through Santos. Everything just went well, we seemed to travel quickly and easily on a road that I will admit could seem quite daunting to some.
Duncs
FollowupID: 666015
Reply By: Member - Mike (SA) - Tuesday, Dec 29, 2009 at 16:18
Hi Bruce, compliments of the season.
I did that trip in October and it is worthwhile. Have just checked my track log.
Distance to Cullymuurra Waterhole was 309.3 and it took me 5 hours 46mins towing an off road camp trailer at an average speed of 53.53 kms with an old GQ Patrol.
My route was via Warri Gate, Santos, Orientos, Nappa Merrie, and then back into SA. By far the roughest section is in SA (I am sorry to say!). Track varies before the bitumen but ain't bad, road works in progress at the bitumen.
Does that help?
From the waterhole it is only 30 mins to Innamincka tops.
regards
Mike
Too little time in the bush!
VKS 737 Mobile 0230
AnswerID: 396804
Follow Up By: Member - Duncs - Tuesday, Dec 29, 2009 at 16:30
Hi Mike,
It is a couple of years since I did that run so it may have changed but where is the bitumen?
Duncs
FollowupID: 665530
Follow Up By: Member - Mike (SA) - Tuesday, Dec 29, 2009 at 16:36
Hi Duncs,
Queensland is sealing the ADVENTURE WAY right to the border and they are almost there!
It is a problem for SA as Buses now get stranded at Innamincka for days - emergency services then have to resupply medications etc!
Gone are the days of remote access - at least from Queensland but it does make a good run from Thargomindah!
all the best,
Mike
VKS 737 Mobile 0230
FollowupID: 665531
Follow Up By: Bruce M - Tuesday, Dec 29, 2009 at 18:09
Thanks folks. Once again, that is very helpful.
Bruce M
FollowupID: 665537
Reply By: Member - Mudduck (NSW) - Wednesday, Dec 30, 2009 at 09:27
When are you going Bruce? as I am leaving Cobar for a similar trip on July 4th 2010.
Cheers Steve VK2UD
Dents are like scratches but with better stories
AnswerID: 396910
Reply By: Peter_n_Margaret - Wednesday, Dec 30, 2009 at 13:17
We came west along the Adventure Way to Innamincka on November 15th this year.
The bit west of the border was "very ordinary", as was the main Strz road until we reached the area where it is being rebuilt.
OKA196 Motorhome
AnswerID: 396942
