C/Trailer Shockies
Submitted: Tuesday, Dec 29, 2009 at 18:38
ThreadID: 74726 Views:4354 Replies:4 FollowUps:7
Hi All,
Recently purchased an '99 Aussie Swag C/T to get back into the camping scene and get away as often as possible. I have been doing a few modifications to it. I have ripped out the old hydraulic shockies and want to replace them with new gas units, and was wondering if anyone has done the same, and if so what brand did they use.
cheers,
Laz
Reply By: Member - John - Tuesday, Dec 29, 2009 at 18:51
G'day, just wondering if gas shockers will be to heavy duty and not allow the suspension to work as designed? Just a thought. John
John and Jan
AnswerID: 396820
Follow Up By: Laz01 - Wednesday, Dec 30, 2009 at 08:44
Thanks John, I didn't give that a thought - maybe I might just talk to one of the local trailer manufacturers.
cheers,
Laz
FollowupID: 665627
Follow Up By: MEMBER - Darian (SA) - Wednesday, Dec 30, 2009 at 10:04
That is a point - I noted when buying some HD gas TJM XGS awhile back for the cruiser that they had a purely hydraulic version available too - the bloke on the counter said that some applications are better off without the HP gas. I guess suspension design and the average load would be the main players - hell - an engineer probably did the original design for A Swag .... maybe he knew what he was doing ? :-o)
FollowupID: 665640
Follow Up By: Laz01 - Wednesday, Dec 30, 2009 at 11:31
I thought an engineer knowing what he is doing is as rare as rocking horse bleep .
cheers, Laz
FollowupID: 665650
Reply By: Notso - Tuesday, Dec 29, 2009 at 19:59
Any replacement shockers should be designed for the weight of your trailer and the spring rates.
Some good advice from the shock suppliers to get an equivalent for the ones you pulled out would be in order.
AnswerID: 396829
Follow Up By: Laz01 - Wednesday, Dec 30, 2009 at 08:49
Thanks Notso,
The only problem is that the ones I have pulled out have no markings on them and are pretty badly pitted - but I will take one to a local trailer manufacturer and see what they can do.
cheers, Laz
FollowupID: 665628
Reply By: itsdave - Wednesday, Dec 30, 2009 at 09:29
I've just had a look under my Aussie Swag (2002 Classic) which still has the original shocks on. They are Pedders Touring Black. Not sure what model camper yours is so may be different otherwise give James a call at Aussie Swag as he's pretty helpful.
Cheers Dave
AnswerID: 396911
Follow Up By: Laz01 - Wednesday, Dec 30, 2009 at 19:01
Thanks Dave,
Tried to give Aussie Swag a call but they must be having the week off between Xmas and N/Year... so I rang Pedders and I am taking the old shockie down there tomorrow for them to measure to quote me a Touring Black.
cheers, Laz
FollowupID: 665718
Follow Up By: itsdave - Wednesday, Dec 30, 2009 at 20:03
Hi Laz
They have done well so far on the C/T having done the Gibb River Rd, Tanami, Buntine and Buchanan Highway's, half way up to Cape York to name a few of the trips. Had them of resently to check them and still as good as new apart from a lot of stone chipping. Will be interested to hear how you go at Pedders tomorrow.
Cheers Dave
FollowupID: 665727
Follow Up By: Laz01 - Thursday, Dec 31, 2009 at 10:52
Hi Dave,
After visiting my local Pedders dealer this morning, I have ordered a pair of Touring Blacks for the A/Swag (Challenger). He said the ones that I pulled off the trailer where only a single action shockie which only restricted the uprise. He also said that they supply these to not only the local camper trailer manufacturer (Robust) but Pedders in general supply to Australian Offroad Campers located on the Qld Sunshine Coast.
If your worried about the stone chipping on your shockies a good idea to protect them is to get a piece of 2-3mm rubber about 50-75mm wide and the full length of the shockie extended and zippy tie it to the top half of it.
Also this will probably open a new discussion but, I heard that Monroe actually make the shockies for Pedders but to their specifications, which I forgot to ask when I was there - will ask Monday when I pick up the new Shocks.
cheers, Laz
FollowupID: 665802
Reply By: MEMBER - Darian (SA) - Wednesday, Dec 30, 2009 at 13:33
Noticed the The Touring Black when looking over the Pedders site this am......is described here.........
My van has independent trailing arm suspension and that maker also used Pedders gas/foam shocks from the 9500 series..... I would have thought that where shocks can be fully protected from stones (not always practical) a mono tube HP gas would always be the best performer. Might be of interest too, that Pedders sell the Bilstein mono tube range - presumably to complete their range of shock types on offer.
AnswerID: 396946
