Van Stabalizers
Submitted: Tuesday, Dec 29, 2009 at 23:20
new boy
Just returned from Christmas in
Perth .The guy across the road had the vertical drop stabilizers I have the angled ones I have always just put minimum pressure on them. This guy cranked the back left only so hard he couldn't turn the handle any more.
Question are the vertical one able to sustain the van weight???
PS I couldn't figure out why you wouldn't lower the front to make level or why only the rear left required adjustment as it was a slabbed drive through very level site,
Reply By: stumbly1 - Tuesday, Dec 29, 2009 at 23:55
I'm certainly no expert and could be wrong, but I don't think I would want to put too much pressure on either! not that the stabiliser might break but that it is distorting the vans shape? putting more pressure on 1 part of the van than the other.
I wound down the stabilisers on the windsor rapid we used to have quite firmly and couldn't close one of the hatches it was so distorted, when I wound them back up the hatch closed as it should.
cheers, Keith
396888
Reply By: pop2jocem - Wednesday, Dec 30, 2009 at 00:10
Hi newboy
For whats its worth I have the vertical type on my van and was told that they are only to stabilise the van when parked not to jack the vehicle up as your mate across the road seems to be trying to do. I suspect he was attempting to level his van and figured that was the only corner that needed lifting.
Cheers Pop
396891
Reply By: The other Norm C (WA) - Wednesday, Dec 30, 2009 at 01:11
Stabilizers are just that stabilizers.
They are not designed to jack up or level the van,
that should be done prior to winding down the stabilizer legs.
Just my opion
Norm
396894
Reply By: Richard Kovac - Wednesday, Dec 30, 2009 at 01:29
Hi NB
I'm pretty new to caravaning and our van has vertical drop stabilizers and I've always wondered what would happen to them if the tyre went flat over night, also jockey wheel? You would have to assume that they can take the weight??
I only wind
mine down till they are tight on the ground.
Richard
396895
Reply By: MEMBER - Darian (SA) - Wednesday, Dec 30, 2009 at 09:51
My van has the ALKO big foot vertical stabilisers (they swing down to verical from the horizontal position) - quite a robust unit BUT the manufacturer and the van maker warn that they can only take a light load, so as to stop the van from wobbling - try and do any jacking and the internal components will be damaged.
396915
Reply By: Member - Graham H (QLD) - Wednesday, Dec 30, 2009 at 10:15
You should use ramps to level crossways and the jockey wheel adjusted for lengthways.
A small level on the floor is best as not all A frames are level when the floor is
Then when its level drop the stabilisers and wind them down just tight but not too tight.
If on grass an adjustment may be required after a few days
396921
Reply By: Ted G - Wednesday, Dec 30, 2009 at 19:49
Hi All
I have stabiliser on the last two caravans, on the last trip the bottom leg dropped out when I lowered it to the ground.
The cause was that the two bevel gears that change the direction have only sirl split pins for the drive, one had broken, I replaced it with a small bolt, not an easy job to do.
Any extra turning to lift the van will break the pins.
The problem of trying to lift one corner is probably the same problem as I have that the shower floor is flat and therefore to get it to drain out the drain hole requires the caravan to be unlevel.
Ted
396989
