Haze Battery
Submitted: Saturday, Jan 02, 2010 at 23:05
ThreadID: 74826 Views:3465 Replies:2 FollowUps:2
I have a 85ah Haze gel VRLA deep cycle battery. Can any of the battery gurus out there tell me the max charging rate and whether I can use a ctek 25amp charger.
Cheers Wilko
Reply By:- Saturday, Jan 02, 2010 at 23:53
Wilk0,
at their web site, max charge rates for HZY12-80 and HZY12-90 are 20 and 22A respectively.
Comparing this with another gel cell battery manufacturer's data, this is already at the high end as the other specifies a recommended charge rate of between 10 and 20% of battery capacity.
Charging it with a 25A charger can potentially lead to dry out of your valuable battery, as the charge cannot be absorbed quickly enough. The effect of this is an overproduction of hydrogen which is beyond the battery's recombination ability.
I'd either get another charger, or buy the same battery again (if the existing one is almost new) and charge them in parallel.
Good chargers have a selector switch which allows for two or more presets of maximum charge currents (I'm not sure about the ctek?).
Also, try to get temperature compensation with this. You want -18mV/deg based on 20 degrees, for your gel cells.
Best regards, batterymeister
AnswerID: 397380
Follow Up By: Wilk0 - Sunday, Jan 03, 2010 at 00:06
Thanks Batterymeister,
I couldnt find that info on their website but heard it on the grape vine that it was the case. I'll have to buy the 15amp charger instead.
Cheers Wilko
FollowupID: 666220
Reply By: RV Powerstream P/L - Sunday, Jan 03, 2010 at 11:30
If you had a multiple outlet charger you could charge each battery independently and that would also offset parallel charging problems if they crop up .
Alternately you could fit a split charge unit that can charge independently and control over volt back feed and monitor each battery individually.
The only complication of the split charge unit is all batteries must be in the same vehicle and all channels must remain connected to a battery at all times.
Ian
AnswerID: 397422
Follow Up By: Wilk0 - Sunday, Jan 03, 2010 at 11:54
Thanks Ian,
Ive got the Haze fitted in my camper. I dont charge it with the cars alternator. I use my generator and a batt charger.
My aim is to run the genset for 2-5 hours when needed to charge up the battery.
I only have a light amp/hour requirement (engel fridge have gas lights)
Cheers Wilko
FollowupID: 666255
