Warning- dead battery & sedan boot positioned gas cylinder.
Submitted: Monday, Jan 04, 2010 at 00:55
Name Not Found
My car battery died in a shopping centre car
park this evening.No warnings such as slow cranking or fluctuating headlight brightness. Thats ok, I can live with that as the battery was getting long in the tooth. Here's the warning. I'm driving a series 3 AU automatic Falcon
sedan with a gas cylinder mounted behind the rear
seat. I need to get into the boot to get my jumper leads and tool box. The remote wont open the boot lock and the gas cylinder blocks entry via pulling the back of rear
seat forward. Luckily there was enough kick in the battery for the dash mounted control to open the boot lock after repeated jabbing. Happy Days. Pauper.
Reply By: More Coffee - Monday, Jan 04, 2010 at 06:38
Times like that you just have to thank your lucky stars!
397535
Reply By: get outmore - Monday, Jan 04, 2010 at 07:55
Im gonna ask the obvios after watching a you tube clip of a blond whos central locking went flat and she called the rac who walked up and unlocked it................... the old fashioned way
397539
Reply By: dirttracker - Monday, Jan 04, 2010 at 09:48
Why wouldn't you use the key entry or am I ignorant and they don't have these anymore!
397545
Follow Up By: Member - Donks1 (NSW) - Monday, Jan 04, 2010 at 10:30
"Name not found" may be "Brain not found"....lol
Steve
666414
Follow Up By: Volvo driver - Monday, Jan 04, 2010 at 10:39
nah, can't use a key for the boot on AU's, at least from series 11 on..
666416
Follow Up By: Member - Royce- Monday, Jan 04, 2010 at 10:54
Modern cars have so many features that they have often lost the basics.... sigh
666423
Follow Up By: dbish - Monday, Jan 04, 2010 at 13:07
I thaught AU had a cable pull just behind the fold down rear
seat ??????
666447
Follow Up By: Road Warrior - Monday, Jan 04, 2010 at 13:16
There is, and he had an LPG
tank in the way so he couldn't reach it.
666451
Follow Up By:- Monday, Jan 04, 2010 at 13:20
The AU 111
sedan only has key entry for the drivers door. Had the gas cylinder not been blocking access to the boot from behind the rear
seat, the boot and the
fuel cap
gate could have been unlocked using the lanyards attached internally. Happy Days. Pauper.
666452
Follow Up By: dbish - Monday, Jan 04, 2010 at 15:09
I gues the simple answer is use a cord to extend it to where you can reach it!!!! Daryl
666474
Follow Up By:- Monday, Jan 04, 2010 at 17:59
For peace of mind, thats exactly what I intend to do and my hope is nobody else gets caught out and does the same. happy Days. Pauper.
666508
Reply By: Fatso - Monday, Jan 04, 2010 at 21:23
I talked to a bloke that left his lights on at the airport & came home to a totally flat battery.
Use the key to open the door & put a new battery in you might say.
Well that's what I thought, only the key in the door is a switch that actuates a solenoid to unlock the doors.
The outcome was the RACQ serviceman removed the bumper bar, to remove the grill, to get at the bonnet latch, to open the bonnet, to put jumper leads on the battery, to open the door.
It was a falcon of some kind.
397649
