Little Desert Victoria
Submitted: Wednesday, Jan 06, 2010 at 00:46
ThreadID: 74926 Views:2767 Replies:2 FollowUps:3
I am leaving Adelaide on Wednesday heading back to Melbourne and want to have a quick look at the Little Desert area so any info or recomended routes would be appreciated,driving a well equiped GU.
Reply By: ozjohn0 - Wednesday, Jan 06, 2010 at 12:25
If you drop into the Dimboola Riverside Caravan Park the owner )Paul) will probably provide you with all the info you need as he and his wife also operate a Eco Friendly resort in the Little Desert.
ozjohn.
AnswerID: 397887
Follow Up By: Member - Vic S (VIC) - Thursday, Jan 07, 2010 at 07:23
ozjohn,
thanks for the info ,I should have thought through my post a bit better as I posted late and left early so could not access the site till now,I did a drive through and found it an interesting area that I intend to return to.
Vic
FollowupID: 666854
Reply By: Crackles - Wednesday, Jan 06, 2010 at 16:15
"....driving a well equiped GU"
A poorly equipped Subaru would tackle anything in the Little Desert. Tracks are easy, pretty flat & the sand not particually soft. Westprint maps have an excellent sheet covering the history, flora & fauna. If you have time I suggest dropping into their shop in Nihll. They also have heaps of books on the area & being so close know the Park inside out so could recommend some highlights.
Cheers Craig.............
Westprint Heritage Maps
Ph:03 5391 1466
Fax:03 5391 1473
6 Park St., Nhill, Victoria, 3418, Australia.
AnswerID: 397921
Follow Up By: Member - Vic S (VIC) - Thursday, Jan 07, 2010 at 07:28
Craig
thanks for the reply,as you can see from the previous reply my post should have been a bit earlier,I did find some soft sand but was not a problem once the tyre pressure was dropped ,it was well worth the detour and will visit the area again.
Vic
FollowupID: 666855
Follow Up By: Crackles - Thursday, Jan 07, 2010 at 16:48
"will visit the area again"
If you liked the Little Desert then you'll absolutely love the Big Desert & Wyperfeld National Park to the north. Sand is far more challenging with a few dunes as difficult as the Simpson. There is also far more history to explore, & quite a few lookouts with marked walking trails if that way inclined.
Cheers Craig.....
FollowupID: 666938
