80 series L/C
Submitted: Thursday, Jan 07, 2010 at 08:59
ThreadID: 74952 Views:2721 Replies:4 FollowUps:1
Hi al,
I own a 80 ser. L/C constant 4wd first registered in 1993. It has a definite "CLUNCK" in the transmission at low speeds. This clunk usually only occurs once and gives me the impression of transmission wind up.
Does anybody know of a cure for this or is it a characteristic of this model?
Reply By: Member - ross m (WA) - Thursday, Jan 07, 2010 at 09:42
When does it happen?
After you have changed from reverse to forward?
Could be the diff pinion.
They all do it to some extent till something breaks.
AnswerID: 398039
Reply By: Hairs & Fysh (NSW) - Thursday, Jan 07, 2010 at 10:29
Hi Ray,
Does it sound like it from the front of the vehicle or at the rear or in the gear box area?
Could be a front shaft uni joint or rear one that's gone.
As Ross said, maybe a pinion bearing/shaft, either front or rear.
Climb underneath and grab hold of the drive shafts and feel for any movement in the uni's. There will be a little movement in the gearing.
Give that a go.
AnswerID: 398044
Reply By: Member - Phantom (WA) - Thursday, Jan 07, 2010 at 13:00
Hi Ray,
I have had that same clunk in mine for the past 14 years. I have had it checked on a regular basis over the years but was led to assume that there is nothing wrong, it is just something inherent in the vehicle. I now adjust my driving to minimise it occurring. I have heard the that others also do the same.
Steve
AnswerID: 398070
Follow Up By: kevanancy - Thursday, Jan 07, 2010 at 16:48
I have a 93 model as well and I think that they all have a bit of play in the driveline from what I can tell , I only hear it if I am a bit careless in the gearchanges (or the missus is driving) .
Kev
FollowupID: 666939
Reply By: Member - Rodney B- Thursday, Jan 07, 2010 at 17:52
The 80 series have the nickname of "the Clunkers" and my 97 model does it also.
Providing you have checked the obvious things like uni joints, suspension bushes and tailshaft splines I wouldn't worry about it.
AnswerID: 398124
