clipse Audio Visual Navigation System AVN 6000
Submitted: Thursday, Jan 07, 2010 at 11:00
Tony @ Naomi
Hi the second hand 100 series I just recently bought has one of these systems fitted, I have worked out most things on it it is more complicated than the old Tom Tom I used to use, can any one tell me how to remove the previous destinations I have read the book but can not get it to work.
Thanks, Tony
Reply By: Member - Allan B (QLD) - Thursday, Jan 07, 2010 at 12:42
Tony, try this:
On screen tap "Route"
Under "Destination" tap "Delete", then "Delete All"
Then tap "Yes", then "OK"
398066
Follow Up By: Tony @ Naomi - Thursday, Jan 07, 2010 at 17:22
Hi Alllan, thanks for the info but I must be doing something wrong I am unable to get delete all to come up.
Thanks, Tony
666945
Follow Up By: Member - Allan B (QLD) - Thursday, Jan 07, 2010 at 18:14
Tony, try deleting from the Destination Archive then:
From the "Menu" screen go into "Setup".
Next to "Delete Previous Point" click on "Delete".
In the new screen "Delete Previous Points" click on "Delete All" at the bottom.
In next screen at bottom, click on "Yes"
666952
Follow Up By: Tony @ Naomi - Sunday, Jan 10, 2010 at 17:28
Hi Allan, thanks for the help deleted it by going into setup.
Another question when you programme in a new route is there any way to view it to see which way it is sending you, on my old Tom Tom it let you have a look at the way it had planned the route.
Thanks, Tony
667661
Follow Up By: Member - Allan B (QLD) - Sunday, Jan 10, 2010 at 18:54
Tony, I think you want "On-route Scroll" to preview the route selected and displayed.
Tap "Route Preview" on the Display Modification Screen.
Then use the scroll touch switches.
Tap " ll " to pause map scrolling.
This is described on page 93 of the user manual.
If you do not have the manual a pdf can be downloaded
here
667686
