cast iron pot
Submitted: Thursday, Jan 07, 2010 at 21:18
ThreadID: 74974 Views:3498 Replies:6 FollowUps:10
Gday
I have found a cast iron pot which is about 2 or 3 ltrs.Trouble is that the pot is covered in rust. I need to know how to clean it properly.
Any good suggestions will be taken and used .
Murray
Reply By: Member - Kiwi Kia - Thursday, Jan 07, 2010 at 21:49
Hi Muzbry,
If you know any engine reconditioners then get them to dump your pot into their caustic degreaser bath. It will come out clean as. You then hose it down with high pressure water (the engine guys should do that for you). Next, you will need to 'season' the pot again, heat the pot and coat it with cooking oil.
KK
AnswerID: 398169
Follow Up By: Member - MUZBRY(Vic) - Thursday, Jan 07, 2010 at 22:04
Thanks KK
I will look into the cleaning bit. I might use some caustic engine cleaner that i have in the cupboard at the factory.
Thanks again
Murray
FollowupID: 667019
Reply By: Best Off Road - Thursday, Jan 07, 2010 at 22:23
Murray,
I can recall as a youngster soaking rusty nails in Vinegar to bring them back to tip-top condition. It's an acid, as opposed to an alkaline (caustic). No real idea on the chemistry but Vinegar is cheaper than bottled water, got to be worth a go.
Jim.
AnswerID: 398173
Follow Up By: Member - MUZBRY(Vic) - Thursday, Jan 07, 2010 at 22:30
Gday
Thanks Jim.
I will now go to bed and think about the job tomorrow.
Good night all, sleep tight
Murray
FollowupID: 667024
Follow Up By: G.T. - Monday, Jan 11, 2010 at 18:04
Acetic acid. regards G.T.
FollowupID: 667826
Reply By: Member - Warren R-Silver Sands - Friday, Jan 08, 2010 at 00:01
What about sand blasting. Nice and clean and no chemicals
AnswerID: 398186
Follow Up By: Richard Kovac - Friday, Jan 08, 2010 at 01:46
If you do that, you will never stop it rusting for the rest of it's like..
FollowupID: 667048
Reply By: Ray - Friday, Jan 08, 2010 at 01:41
If you have time immerse the pot into a 50/50 brew of molassis and water. Pull it out every week and give it a brush. It will come up like new in a month. If you are in more of a hurry you can mix a solution of plain washing soda and water and immerse it. Use a battery charger and hook the positive to a bit of scrap steel in the bucket and the negative to the pot.Make sure the two don't touch, The rust will come off the pot and stick to the anode. You can google electroulisis (sp) rust removal and find out all about it. We old engine and machinery restorers use both methods a lot.
AnswerID: 398190
Follow Up By: Member - MUZBRY(Vic) - Friday, Jan 08, 2010 at 06:14
Good morning
Thanks Ray
FollowupID: 667050
Follow Up By: xcamper - Friday, Jan 08, 2010 at 09:35
In a previous life,(when I worked for a living), I had access to a Molasses storage tank, (huge one), dangling rusty parts in the pure molasses was the best and cleanest way , but it can take time.
pete
FollowupID: 667077
Reply By: racinrob - Friday, Jan 08, 2010 at 07:30
I collect old camp ovens, ( yeah I know but it's harmless) and I cook in them too.
The best way of cleaning them is by electrolysis which removes even the worst rust without damaging the pot which sand blasting and molasses will do.
Put the pot in a large plastic container like a fish box, cover with water and hook it up to a battery charger, black lead to the pot, red lead to a sacrificial anode also in the water eg a piece of steel rod being careful not to let the two touch. Depending on how many amps your charger puts out but in a couple of days the pot will be like new. Don't let the alligator clips on your leads touch the water as they will corrode.
To keep the pot good you should then season with olive oil it but that is a whole new process.
Rob.
AnswerID: 398198
Follow Up By: Member - MUZBRY(Vic) - Friday, Jan 08, 2010 at 10:55
Gday
Thanks Rob.
FollowupID: 667108
Follow Up By: Member - Kevin B1 (WA) - Friday, Jan 08, 2010 at 10:57
Well how about that,have never heard of that one before. I will give it a try myself one day. You learn something every day and this one I will defiantly file away for future use.
FollowupID: 667111
Follow Up By: trainslux - Monday, Jan 11, 2010 at 12:49
concept is here, and if you google further.
http://www.sksboards.com/smf/index.php?topic=31740.0
works well.
Re cast iron.
I would just put it on the fire, and heat it up.
Add small amounts of water to it, and let the steam clean it.
Once clean, and rust removed, let cool.
Then warm, and add oil as mentioned and allow it to soak into the pot.
Several applications with a warm oven will do it.
Best non stick even cooking you can get.
Trains
FollowupID: 667788
Reply By: Member - Duncs - Friday, Jan 08, 2010 at 13:22
Muzbry,
You have advice on cleaning the pot that I will not argue with.
Nearly 30 Years ago I found an old cast iron pot just like you did. I applied heaps of elbow grease and steel wool off and on over about a month and it looked beautiful but it was hard work. I like the sound of electrolysis.
Seasoning will help prevent ever having to do that cleaning thing again.
My Gran, bless her, said I should fill it with oil and put it on the lowest heat I can for as long as I can. I put it on the smallest burner on our gas cook top turned down as low as I could get. I left it there all day. Could not bring myself to leave it on overnight but it the morning it went back on, same oil. It became the most non-stick cooking pot I have ever had.
To keep it that way I always wipe it out while it is hot and never ever use soap of any description. If something does stick I put oil in the pot to cover the offending stuff and heat it slowly, it always comes off.
Happy cleaning and even happier cooking
Duncs
AnswerID: 398267
Follow Up By: Member - Duncs - Friday, Jan 08, 2010 at 13:24
I forgot to mention that while it was heating with the oil in it I basted the outside with the oil from time to time. This keeps the outside from rusting too.
I used a small bristle paint brush, natural fibre, the synthetics melt.
Duncs
FollowupID: 667146
