GPS - Notebook Computer.
Submitted: Monday, Sep 29, 2003 at 18:29
ThreadID: 7501 Views:2663 Replies:2 FollowUps:6
How do I make my notebook into a moving map display GPS.
Hi there Guys and Gals.
I have been led to believe that I am able to use my Notebook as A moving map display GPS. IS this correct? If so what do I need to buy to make it all work.
See you on our travels
H,K & A
Reply By: Member - Gary - Monday, Sep 29, 2003 at 18:50
dolfn
- You will need a GPS and suitable software such as Oziexplorer. Your notebook will need to be able to be connected to the GPS, generally through the serial port. Do a search on this forum and you will find lots of info.
You will also need to consider a power source for your notebook as you travel.
Oziexplorer can be purchased through the exploreoz shop as can GPS's.
Good luck Gary
Dead in the City - Alive in the Bush
AnswerID: 32336
Follow Up By: Willie - Monday, Sep 29, 2003 at 20:32
And iff like mine, your Notebook does not have a serial port you can buy the correct connector to USB from Jaycar.
WillieNever a dull moment
FollowupID: 23103
Follow Up By: Member - dolfn - Monday, Sep 29, 2003 at 20:45
will any gps do? Can I buy areal basic model? All I need is the info to get the lat and log is that correct?
H,K & A
FollowupID: 23107
Follow Up By: Willie - Monday, Sep 29, 2003 at 21:10
dolfn,
If your GPS can find Lat/Long and UTM it should be able to transpose the info to the Notebook. The GPS has to have a cable connector port, of course. I personally do not find the need for a moving map. I use my GPS, Notebook and Oziexplorer to pin point positions and rely on bush sense for the rest. Have only worked out about 10% of the capabilties of the soft ware.....Don't forget, you need to load digital maps into your Notebook as the GPS will only give you a basic reading from its software.
Willie
Never a dull moment
FollowupID: 23110
Follow Up By: Member - dolfn - Tuesday, Sep 30, 2003 at 12:54
So would the magellen 310 be ok with accessories? What make and model do you use?
Thanks for your help
H,K & A
FollowupID: 23152
Follow Up By: Member - Bob - Tuesday, Sep 30, 2003 at 14:10
Magellan 310 or 315 are fine.Bob
FollowupID: 23160
Follow Up By: Willie - Tuesday, Sep 30, 2003 at 19:13
Hi dolfn,
I have a Magellan 330....2002 model. Works well for me.
Willie
Never a dull moment
FollowupID: 23172
Reply By: chopper - Monday, Sep 29, 2003 at 18:52
What Gary said!!
AnswerID: 32338
