Waeco Problems
Hi Guys,
My brand new Waeco cuts out at 12.6v even though it is set to lo, (apparently it should cut out at 10.5v). It runs well on 240v.
I have tried it on two different batteries which hold good charge and also in the car with the engine running.
After getting the run around by Waeco and the reseller, I spoke to the authorised repairer who said it would take a month of Sundays to rerpair, which makes it hard to fit the repairs in between camping trips.
Are there any possible solutions, apart from bending the Waeco man over and placing the fridge where the sun don't shine. (is this product suitable for the purpose for which it was supplied)
Reply By: Time - Monday, Jan 11, 2010 at 18:21
Sounds like the typical Waeco wiring problem to me.
The most common problem re volts is the poor cigarette lighter plug on the end of the fridge power cable. Common fix is to use "Hella" plugs or "Anderson" plugs. I had similar issues and 50 amp Anderson plug solve the problem. (The "power" lead to the plug being direct wired off the Aux battery using 6mm cable, suitable fuse installed close to the battery end of course).
AnswerID: 398859
Reply By: greybeard - Monday, Jan 11, 2010 at 18:54
where and under what conditons are you measuring the cut off voltage?
the fridge ( like any brand ) will use the voltage seen inside the fridge itself. so if you were to measure the open circuit voltage or measure it at the source ( battery ) it won't include the voltage drop that can occur accross the wiring and DC plug.
If the wiring between the fridge and the battery ( including the plugs and fuses ) has enough resistance then as the load ( current ) increases the voltage seen by the fridge ( and it's low volt cut out ) will be less than the cut out voltage. And then the fridge won't work.
Alternatively there was a problem a couple of years ago with an internal poly fuse inside the waeco that can give similar symptoms.
Also try Waeco direct and they may be able to point you to another repairer who isn't so busy.
i would eliminate the wiring and connectors first, especially if you have a new fridge.
AnswerID: 398861
Reply By: Member - Flynnie (NSW) - Monday, Jan 11, 2010 at 19:29
Geoff
I have just done a bit of fussing over my old Waeco. Sometimes you need to play around a bit with the switches. Try the medium and high settings and see what happens. Yes I know moving the opposite way but just try it to humour me. Also try the emergency over-ride that should run the fridge flat out. You will get a better idea of what is or is not happening.
When you used the other batteries did you rig the fridge direct to them or did it go through the vehicles wiring? You do need good wiring. I had my sedan wired with console and boot sockets by an auto electrician. A wiring upgrade is essential.
I have noticed on mine of late it does not like to run on turbo mode unless the vehicle engine is running so now I don't use turbo. Could be worn sockets. Do not really need to find out as it still works on normal setting. The Waeco is used in my car and an Explorer on my trayback. The cruiser needed a dual battery and dedicated wiring before it could be used. This leads to your last question.
"Is this product suitable for the purpose for which it was supplied?". Not being privy to how you bought it cannot be categorical. In my experience the Waeco is a very satisfactory fridge and quite suited to its intended purpose of a recreational fridge that can also work as a freezer. There are better and dearer fridges. Which one for which person is often a matter of personal choice and how hot the intended environment that it will be used in.
Just an aside an slightly off topic but a lot of people read these threads looking for information. Car fridges are a very expensive way of keeping things cool. The cost of the fridge could be a lot less than half the outlay needed to get the system working properly. Dual battery installation can cost well over $1,200. The Explorer has cost me about $3,500 to get operational on the cruiser. A lot of people really would be better with an ice box. When you get the fridge you are then committed to spend the extra to get it working properly. At least an ice box you know what it costs and how much ice costs.
Sorry for getting on the soap box on your message.
Flynnie
AnswerID: 398866
Follow Up By: Shaker - Tuesday, Jan 12, 2010 at 12:49
I bought a $200.00 Waeco Ice Box to supplement the Engel, cost me $70.00 for ice over 10 days.
I can assure you that their ice boxes are no better than ther fridges!
FollowupID: 667944
Follow Up By: Member - Flynnie (NSW) - Tuesday, Jan 12, 2010 at 19:20
Shaker
Ice boxes. There is a review of them in 4X4 Australia current edition (February 2010). I have only glanced at it. Looks interesting reading.
My point is it is expensive to set up a fridge (dual battery, wiring, isolator, wages etc) and it is very possible to get completely carried away with spending too much on a fridge and all its support gear and finish up with very expensive cooling if you divided cost by days actually used.
Some one thinking about a fridge should do the sums first and I would add be not overly influenced by saving a few dollars on the fridge as it does not make much difference to the total cost.
Flynnie
FollowupID: 668020
Follow Up By: howesy - Tuesday, Jan 12, 2010 at 19:57
Bejesus Shaker how big are these ice boxes, the 12 yr old jack daniels plastic esky keeps ice for 3 days no sweat. probably cost me half that for 10 days must be a big sucker of an ice box.
FollowupID: 668029
Follow Up By: Shaker - Tuesday, Jan 12, 2010 at 22:38
The ice box is 40 litres & is hopeless, as was my Waeco fridge.
I should have have known, but I didn't think they could stuff up an ice box as well, but they managed!
FollowupID: 668084
Reply By: MEMBER - Darian: SA - Monday, Jan 11, 2010 at 20:19
The poly fuse issue should be out of the question for your new fridge - they have been fixing that issue under warranty for years now.
Re voltage - you can test your actual voltage at the fridge (or close to) by spiking through the insulation in the fridge's power cable with sharp multimeter probes - just enough to get into the first strands of copper, while the fridge is running - and without damaging the wiring - as others have said, that will probably reveal lower voltage near the fridge than you have considered to date. If so, you could then work back from there to see where it's being lost. The standard Waeco fridge cable has a fair amount of loss in itself - just about anything else is better !
AnswerID: 398875
Reply By: Rosco24 - Monday, Jan 11, 2010 at 21:34
Had the same problem. Re-wired to the back plug with heavy cable - problem gone. Waeco are great fridges but are very fussy about power. Good cable and connectors do the trick. Cheers.
AnswerID: 398900
Reply By: Wizard1 - Tuesday, Jan 12, 2010 at 15:19
Had a Waeco CF50 for over 7 years. It has been on every trip we've done on 12V and off the transformer using 240V. It has been the bar fridge for parties and a freezer for big fishing trips.
We use Engels and work and they play up all the time.
It has lived in the back of the Prado down the Oodnadata & Birdsville tracks, along some of the back roads of WA, the NT, Fraser Island and never missed a beat. Any problem has been, as suggested, poor battery connection or inadequate wiring to the fridge but never the fridge.
It is the best $$$ I have ever spent on a camping item. Is it fit for its purpose?..ABSOLUTLEY!!!!!
Would I buy another one?...ABSOLUTELY !!!!!!!
AnswerID: 398990
Follow Up By: Member - Geoff H (QLD) - Wednesday, Jan 13, 2010 at 13:59
I'm pleased someone has a good story about their Waeco, I thought I'd bought a $1000 lemon, especially with the after sales service I recieved.
Waeco, the re-seller and the repairer all insisted that the battery was at fault even after I used 2 batteries and 4 multimeters to test them, surely they would have known that the plug they supply is of questionable quality, everyone else seems to know.
Don't know why they put a $2 plug on a $1000 piece of equipment that is so important in the bush.
Hopefully I won't have to put up with cold beer again, let along the rotten food.
Geoff
FollowupID: 668163
Reply By: Member - Mike DID - Tuesday, Jan 12, 2010 at 16:59
"After getting the run around by Waeco and the reseller,"
You should explain to the reseller that under the Trade Practices Act you're entitled to a full refund if the goods aren't of merchantable quality and you want the refund now.
AnswerID: 399002
