All Terrain (AT) Tyres Feedback
Submitted: Tuesday, Jan 12, 2010 at 17:18
ThreadID: 75130 Views:4932 Replies:6 FollowUps:4
We have split rims on our Troopy, we have been using Dunlop 7.50/16 tyres and and would like some advice for an alternative as these tyres are failing.
Advice please !
Reply By: get outmore - Tuesday, Jan 12, 2010 at 17:21
do you want to stick with the splittys or go tubeless
if your not changing wheels i would suggest going to 235x85x16 tyres
AnswerID: 399009
Follow Up By: Member - Sylvia & Peter B (WA) - Tuesday, Jan 12, 2010 at 19:15
many thanks for your input
we are undecided whether to change from split
we appreciate all input
your feedback will help make our decision the better one
cheers peter
FollowupID: 668019
Reply By: racinrob - Tuesday, Jan 12, 2010 at 17:29
Hard to give you any advice without more details, why and how are they failing ?
I had problems with the same tyres/rims and was advised to upgrade to "E" rated 265/75 R16 tyres on Sunraysia rims to handle the weight I was carrying over some pretty ordinary outback roads. Others will disagree but it cured my problem, I've had no more worries after many remote area trips.
rob
AnswerID: 399011
Follow Up By: Member - Sylvia & Peter B (WA) - Tuesday, Jan 12, 2010 at 19:26
blowing out through sidewall
we have been trying to get help from dunlop through beaurepaires for 3 months
so far nothing worthwhile
any advice as to any other safety body or any organisation that may help would be appreciated
fortunately the troopy was not heavily loaded nor was speed excessive so we didnt overturn
FollowupID: 668022
Follow Up By: Member - Sylvia & Peter B (WA) - Tuesday, Jan 12, 2010 at 19:31
fortunately the troopy was not heavily loaded nor was speed excessive so we didn't overturn
FollowupID: 668023
Reply By: The Rambler( W.A.) - Tuesday, Jan 12, 2010 at 18:06
The Dunlop Roadgripper 750/16 tyres that come with thenew Troopy have never been the best option and you would be llucky to get 35000k's out of them.I have been using split rims on troopys for many years and find the best tyre for a wide range of conditions is the Hankook 235/85/16 AT.If you want to save a few dollars buy the Kingstar in the same size as it is EXACTLY the same tyre as the Hankook with a different badge.
AnswerID: 399018
Follow Up By: Member - Sylvia & Peter B (WA) - Tuesday, Jan 12, 2010 at 19:32
Thanks for you feedback. Will follow up on you suggestion of the alternative Kingstar and Hankook.
FollowupID: 668024
Reply By: Ozzie Nomad - Tuesday, Jan 12, 2010 at 21:18
Hi Peter & Sylvia,
The Road Grippers that Mr Toyota supplies on the troopy are only adequate for normal roads and good dirt tracks. They are the cheapest way out of it for the factory.
235/85 R16 LT's in something like BFG All Terrains or Coopers will take anything you can load in & on a troopy, and should give you at least 80,000 klms.
The "LT" means Light Truck, and they are bullet proof.
The only good thing about split rims is they are easier to get the tyre off.
A pair of Tyre Pliers in the recovery gear sorts that out.
The best tyre in any given situation is likely to be the worst in the opposite type of terrain.
Life is full of compromises, and opinions are like armpits........Most people have at least one, and they pretty much all stink.
Happy hunting,
Ozzie Nomad
AnswerID: 399049
Reply By: Member - John and Val - Wednesday, Jan 13, 2010 at 12:12
Hi Sylvia and Peter,
We have had our troopy for about 20 years and ran splits on it until about 3 years ago when we got fed up with flat tyres coming across the Simpson.
Changed to 15" Sunraysia rims and have been running with Maxxis Ats pretty much ever since and have been very happy. During that time we have done lengthy remote area trips where there is a real risk of sidewall punctures so we regard tyres as pretty much disposable items (after all one tyre costs similar to a refill of fuel!). For this reason we have chosen to go with a cheaper tyre rather than the more expensive versions that can still get a sidewall stake.
The Maxxis have performed and worn very well and apart from a 4" nail have given us no problems at all.
Val
J and V
- Albert Einstein
AnswerID: 399150
Reply By: Member - Prickle (SA) - Friday, Jan 15, 2010 at 22:58
S and P,
We had a Hi Lux with splits and the Road Grippers, great number of Km s out fo them (abt 90k) BUT, kept getting punctures?
REASONING: No less than 1x a year I would take all the wheels off and wire brush/grind back the rims, but after, at different times going through water etc, the rust would build up. This becomes quite abrasive and wears through the chube (?? on spelling) , hence flatties.
Get rid of the splits.
Enjoy.
Russ
Life-often hell but never boring.
AnswerID: 399652
