Slight Shudder on take off with 100s 5 speed auto?.
Submitted: Wednesday, Jan 13, 2010 at 20:26
ThreadID: 75182 Views:2910 Replies:5 FollowUps:4
Has anyone experienced this,? Its Not all the time, I was told it could be the diff oil in need of changing????. The auto changes smooth as , no abnormal noises, or anything. Driveline is fine,cvs.etc., ......Ideas as to what it might be?..Thanks.
Cheers Axle.
Reply By: Member - Graham H (QLD) - Wednesday, Jan 13, 2010 at 21:51
How many K's
Has auto been serviced, what else has been serviced and how many K's ago.
The more info easier to get a sensible answer.
AnswerID: 399271
Reply By: Member - Andrew (WA) - Wednesday, Jan 13, 2010 at 21:55
Do you grease up the uni joints every 10k....I hear this can cause issues if not done and can also cause a shudder if the yoke is 'over greased'
I experienced the same problem, greased up everything and it went away.
AnswerID: 399272
Follow Up By: Member - Andrew (WA) - Wednesday, Jan 13, 2010 at 21:57
What part of the country in now Graham??? Lucky you're not here... 35 degrees up to 40 back to 37...etc......HOT HOT.
You lucky %#&#((^@!
FollowupID: 668245
Follow Up By: Member - Graham H (QLD) - Thursday, Jan 14, 2010 at 09:48
Thats not hot Andrew
Had 51 at Pt Augusta and 4 days over 45 here at the large metropolis of Mt Compass in the Adelaide hills
LOL
FollowupID: 668294
Follow Up By: Member - Andrew (WA) - Thursday, Jan 14, 2010 at 20:38
I think we hijacked this post...
51 at Port Augusta??? SA??? we all know how those SA's can go overboard...can't even trust a thermometer over there....next you'll tell me they have a decent footy team!
FollowupID: 668401
Follow Up By: Member - Graham H (QLD) - Thursday, Jan 14, 2010 at 20:57
Should be Ok I bought it in Perth
Footy come on I wouldnt watch that aerial pingpong
FollowupID: 668403
Reply By: fisho64 - Wednesday, Jan 13, 2010 at 22:11
Id be looking at the drive shaft first up also. Easiest/cheapest to check, and also the more likely culprit.
Auto is also a possibilty but these are very strong, reliable autos with an impeccable reputation. However its not impossible.
If its the sealed version (post early 03) have a look for any leaks that might indicate that its short of ATF. If there is no leaks tehn its not the problem (short of fluid)
AnswerID: 399275
Reply By: Voxson - Thursday, Jan 14, 2010 at 09:18
Somebody once told me,, so i dont know how true it is......
That can happen when you have a lifted vehicle with an auto,,, as your constant torque on take off makes the pinion angle worse and a shudder becomes apparent,,,, but only on take off..
*shrugs shoulders*
AnswerID: 399322
Reply By: landed eagle - Thursday, Jan 14, 2010 at 12:28
Is the slight shudder only after starting the engine and taking off?
The Mitsubishi ABS makes a small vibration just after starting the motor as part of its self diagnosis check.
My Triton does it,the wife's Lancer does it and her Magna wagon work vehicle did it too.
Dont know if the other manufacturers systems do the same thing.
AnswerID: 399349
