Tuesday, Jan 19, 2010 at 12:14
Hi Moose,
The most probable source is the ECU, but there are a mulltidude of things which run microprocessors (a common source) these days, incl auto trans, electric aerials and windows. Even my dumb GU 4.2 diesel emits spurious signals which interfere with a mid-band VHF 2-way. The source often can be easily located, but stopping it is another thing (ask Disco and 100-series T-diesel owners). And I have a spurious signal from a nearby mobile base station near home.
The reason why you get the squelch staying open after a transmission is due to the hysteresis in the circuit; it will operate at one level of signal and drop out at a different level. The spurious signal is enough to keep the squelch open after a transmission, but not enough to open the squelch from zero signal.
Without getting too technical, it is possible for one particular design of receiver to pick up an unwanted signal, but another receiver will not. Sometimes the frequency of the unwanted signal is totally different to the receiver frequency, but design of the receiver dictates whether it rejects that unwanted signal or not.
Sorry I can't be of more help.
Gerry
669304
