Diesel eratic idle speed
Submitted: Tuesday, Jan 19, 2010 at 10:02
Microlon Australia
Hi all,
My van is a 2005 Kia Pregio 2.7L diesel with around 60,000 Km.
When cold the idle speed is low (500 rpm) when warm it is around 750 to 800 rpm.
Also when warn sometimes the idle speed drops very slowly down to +/-550 rpm.
I then put my foot gently on the accelerator and keep it in the same position, the engine runs a bit faster and then the rpm go up around 300 revs with the accelerator still in the same position.
Apart from that the van goes
well and burns 8.7 L / 100 Km on long runs.
Does anyone have a solution for this annoying problem?
Reply By: Wayne (NSW) - Tuesday, Jan 19, 2010 at 10:27
Does the vehicle have the air con on or climate control fitted.
This could explain why when cold, the air con is off and the rpm is low 500 RPM.
When it is warm the air con is on and the rpm is higher. The variation in rpm could be the air con cutting in and out.
Wayne
400149
Follow Up By: Microlon Australia - Tuesday, Jan 19, 2010 at 21:39
Thanks, I do not use the air con.
669365
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, Jan 19, 2010 at 10:28
Maybe a pump air leak or worn valve or even something as simple as a vacuum leak.
It's 5 years old maybe time to trade it in anyway if it's used for business.
Dave
400150
Follow Up By: Microlon Australia - Tuesday, Jan 19, 2010 at 21:41
Thanks, I will investigate.
Not about to trade it in, only 60,000 Km
669366
Reply By: Alloy c/t - Tuesday, Jan 19, 2010 at 10:35
Probably caused by the additives you put into the
fuel tank and into your oil.
400153
Follow Up By: Microlon Australia - Tuesday, Jan 19, 2010 at 21:51
Thanks,
If you have not tried it yourself don't knock it, your way of thinking is most likely based on unsubstantiated rumors.
Many drivers come back for more.
669367
Follow Up By: Alloy c/t - Tuesday, Jan 19, 2010 at 23:00
No substantiated proof that the snake oil you sell works either ,,just for once be truthfull and admit that the Only reason you put up the query about your vehicles problem was to push your snake oil product back into the
forum ..
669388
Follow Up By: Microlon Australia - Wednesday, Jan 20, 2010 at 08:50
I believe this
forum is to share information and help each others.
Your contribution has not helped me to resolve my problem, thanks anyway.
669415
