Saving route's, Garmin nuvi 760
Hi all,
I'm trying to figure out how to save a travelled route onto my nuvi 760.
I can name and save a start point as well as a finish point, but how do I save the actual route that I have travelled.
The start point and finish point are 900 meters apart, however, i have to visit 120 points in between, over and area of about 10 sq Km.
The only way I can this would work is by individually set each site as a waypoint and then load them in to a route.
I have the "trail" function enabled, which leaves the blue line from where i have been and I thought it would be as simple as just saving last route, but I cannot workout how.
Does the 760 has this function?
Shane
Reply By: DesF - Thursday, Jan 21, 2010 at 16:15
Hi I have the same unit, and I just save the tracks to my PC, in Mapsource and then save them in to a file . they only show on the unit as one track but when you download them they show up as individual tracks.
Cheers Des.
AnswerID: 400470
Follow Up By: Member - Tony V (NSW) - Thursday, Jan 21, 2010 at 17:21
Just a quick follow up on DesF reply, Mapsource files also show time of day and speed as well.
FollowupID: 669636
Follow Up By: Member - Steve M (SA) - Thursday, Jan 21, 2010 at 17:25
There are other methods - have a look at this one ..
Nuvi760 hidden track log
FollowupID: 669637
Follow Up By: Member - Shane D (QLD) - Thursday, Jan 21, 2010 at 19:29
Thanks Steve, thats what I'm looking for, I'm not running thru a lappy and everything else that has been sugested is all above me I'm afraid, thanks none the less.
Shane
FollowupID: 669650
Reply By: Member - Doug T (NT) - Thursday, Jan 21, 2010 at 17:39
As DesF has said but after you have the recorded track on the PC showing in Mapsource CN you could make a route over the track, save it then upload the route to the GPS unit ,
Also the list of separate tracks can be all joined together to make 1 long track,
AnswerID: 400474
Follow Up By: Member - Shane D (QLD) - Thursday, Jan 21, 2010 at 19:46
Thanks for the tip, but i'm not running my GPS thru a lappy.
One of the previuos replys gave me a link detailing how to access a hidden menu which I will try tomorrrow.
The problem is I'm doing a lot back tracking and crisscrossing myself in sort of a grid pattern and really need to be able to follow the path shown to me, my 760 shows everywhere I'v been, some of the time on roads that aren't on a map.
I'm hoping that the hidden menu mentioned earlier will do just that.
Shane
FollowupID: 669655
Reply By: Member - Shane D (QLD) - Friday, Jan 22, 2010 at 19:21
The simple ideas are always the best!!
I tried the idea on the above link that was posted , but doesn't work on my nuvi.
Just switched it off and use it next when I need it and the trail will be still there, thanks mate.
Shane
AnswerID: 400640
