Penetrol dilemma
Submitted: Wednesday, Jan 27, 2010 at 10:49
Member - Supertramp (NSW)
G'day,
I have read lots of posts on using Penetrol, so i went to the Bunnings, and found two different Penetrol cans.
One is Penetrol Rust Treatment and one is ESP easy surface prep Penetrol .
I am guessing others went for the rust treatment not ESP? Am i right?
N
Reply By: Member - Wamuranman - Wednesday, Jan 27, 2010 at 11:45
Correct
401286
Reply By: D200Dug- Wednesday, Jan 27, 2010 at 17:21
It depends on what you are doing :-)
The ESP is magic if you are painting a surface that is less than perfect.
I have used it many times it also slows or stops rust.
Both products are good just choose the one for the job !
401332
Follow Up By: Member - Supertramp (NSW) - Thursday, Jan 28, 2010 at 18:28
Well i am using it to spray a protective coat underneath and inside the body etc, the paint quailty is crap on the latest models.
Thanks for the info
670842
Follow Up By: D200Dug- Thursday, Jan 28, 2010 at 18:46
The rust one will work
well for that
Try the paint one if you have problems getting a smooth finish with oil based paint.
An undercoat of ESP and a small amount in the paint helps it to flow evenly over surfaces and adheres to surfaces much better than just ordinary paint.
670845
