Natmap and Windows 7 Help
Submitted: Wednesday, Jan 27, 2010 at 18:56
ThreadID: 75546 Views:4336 Replies:5 FollowUps:2
I have just purchased Natmap 1:250 Topo Raster Map of Australia.
It comes with a Map viewer ect. However It wont load using Windows 7.
Anyone got any fixes for this.
Note loads on my mates computer who has Windows XP no problem.'
Wayne
Reply By: The Explorer - Wednesday, Jan 27, 2010 at 19:01
Quickly...This has been asked before (several times) though think the issue was with Vista. Do a search of older threads.
AnswerID: 401349
Reply By: Kumunara (NT) - Wednesday, Jan 27, 2010 at 19:29
Wayne
I use oziexplorer with windows 7 without any issues.
If you haven't got oziexplorer you should send an email to the Geoscience site site feedback@ga.gov.au and see if they can assist
Tjilpi
AnswerID: 401357
Reply By: Notso - Wednesday, Jan 27, 2010 at 20:28
You say it won't load, do you mean it wont install, or wont run once installed.
I have it running fine in windows 7.
If it won't install, run the Installer in Compatibility mode for windows XP SP 3
AnswerID: 401376
Follow Up By: Member - Wayne B (NSW) - Wednesday, Jan 27, 2010 at 20:51
Thanks guys.
Yes It wont install using Full Installation. Appears to install when "Typical " Installation is used
Found a note in Geoscience about this problem said to do a "Typical" install then copy maps ect onto hard drive. The installation has now worked using the Typical Installation. However I dont understand how to use the Map Manager to configure the Nat Map Raster Program.
Wayne
FollowupID: 670687
Reply By: Willykj - Wednesday, Jan 27, 2010 at 20:30
I have loaded on 2 computers with Windows 7 with no problems..
Willy
AnswerID: 401377
Reply By: Member - Doug T (NT) - Wednesday, Jan 27, 2010 at 23:19
Probably just an ID ten T ERROR .
AnswerID: 401398
Follow Up By: Kumunara (NT) - Friday, Jan 29, 2010 at 14:15
Doug
From reading the posts I believe that you are correct.
Tjilpi
FollowupID: 670978
