Water Injection
Submitted: Thursday, Jan 28, 2010 at 13:24
margs tribe
Gday all,I have a 97 model 40th aniversarycruiser with a aftermarket turbo on it . I am trying to keep my EGT'S down but am unsure of doing it. Has anyone, or does anybody know of anybody who has put
water injection onto a 1HZ motor. Or will gas keep my EGT'S down?, Thanks Jugga.
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Jan 28, 2010 at 13:46
Someone will correct me if I'm wrong but
water injection in a diesel wouldn't be a good thing.
This is reserved for petrol engines that have much lower compression ratios.
Backing the foot off as in slowly lift it off the floor until a drop in performance is felt and then lower back down a smidge will give the engine only the amount of
fuel it needs. Overfuelling will cause the egt's to rise.
Or go down a gear.
Dave
401474
Follow Up By: Member - mazcan - Thursday, Jan 28, 2010 at 14:09
hi margs tribe
you havent said if you are towing anything but if you are i would suggest that maybe the load is to much for the engines capacity so reduce the load /weight and or the above by tour boy
every engine has its limitations in pulling power no mater how
well it runs
670807
Reply By: Hairs & Fysh (NSW) - Thursday, Jan 28, 2010 at 14:17
Hi Jugga,
And welcome to the site.
I don't have an answer to your question, It maybe better asked to the guys at
Lcool, become a member, Anything to so with 80's they'll know about it.
I'm sure you will get an answer to what your chasing there. A very helpful bunch they are. Now I'm not say the knowledge isn't helpful here either. ;)
401480
Reply By: _gmd_pps - Thursday, Jan 28, 2010 at 15:01
Several ways to reduce EGT in a Diesel.
1. Install a EGT gauge and drive accordingly. Shifting down and running the engine at it's sweet spot is one way.
2. Install a larger exhaust. I have a 4" dual exhaust on my Duramax and it does
reduce EGT by 5-8% under load.
3.
Water vapour injection is a possible technology (used in the US on diesels) and can be triggered by EGT temps or revs, but I think it only makes sense on larger volume engines.
Gas will increase EGT when you keep the accelerator floored. Gas DOES NOT reduce EGT primarily. It is only a secondary effect when you back off with the accelerator due to higher power.
If the first 2 methods does not keep it a bay you either ask too much of your engine or your engine does not burn all the
fuel it should. Injector cleaning might be an idea
good luck
gmd
401483
Reply By: olcoolone - Thursday, Jan 28, 2010 at 15:29
Is the exhaust gas temp you are seeing within spec and safe for the type of vehicle you have and the type of driving you do or is above acceptably levels?
No use trying to fix a fault that isn't there in the first place.
401485
Reply By: Banditfj - Thursday, Jan 28, 2010 at 16:18
Yes,
water injection will reduce EGT's, will also make it run better. Most owners set the injection up so that it comes on at certain boost pressures. For security, you could set yours up with a thermo switch set to your desired EGT and let it come on then. check out
this site for a couple of guys who've fitted water/meth injection.
Intercooling will also drop your EGT's and will be a lot easier to install. What are your EGT's at currently?
401488
Reply By: Member - Oldplodder (QLD) - Thursday, Jan 28, 2010 at 17:02
I was getting high EGTs on my pajero, such as 840c before the turbo.
Turned the
fuel back slightly so I get max of 700C before the turbo.
Almost the same performance, and EGTs OK now.
Need lots of
fuel to get high EGTs :o)
I did try some extra boost (3 psi more) for more air, but not that much extra performance, and just working the engine harder.
I also change down to a lower gear earlier too, 2500 rpm instead of 2000rpm, when climbing hills with trailer on back, and sit on 2500/2800 instead of lugging it at 2000/2200. More air, better cooling to the combustion chamber, lower EGTs.
Did think of a
water spray on the intercooler fins to lower EGTs. But how much
water would I need? A pain to keep topped up. Friend in EVO with
water injection soon uses his 2 litres when it is going hard.
401491
Follow Up By: GerryP - Thursday, Jan 28, 2010 at 21:13
Must agree with Oldplodder. I have a 1HZ with aftermarket turbo and had to 'play' with
fuel adjustment quite a bit to get a good balance between EGT and performance. Too much
fuel and you get high EGT so you end up backing off and not using the extra power in any case - especially when towing. When set about right, you'll have adequate power, but be able to sink the boot when you need it. Keep the EGT to around 520 (post turbo) max.
Just a warning though, only make very small adjustments of say 1/8 turn at a time, then try it out under varying conditions.
oh - and don't boost over 8 psi on the 1HZ, the pistons won't like it for too long.
Gerry
670874
Reply By: Member - Bucky - Friday, Jan 29, 2010 at 08:03
Jugga
I am unsure about
water injection
BUT
Changing your driving habits, will be the best way to drop your EGT's.
Better to never load up the motor, ie change down gears as soon as you feel the motor drop "free reeving".
When I tow I seldom use 5th gear (only down
hill) I just keep the revs up.
Bucky
401578
Reply By: sculls - Friday, Jan 29, 2010 at 10:33
G'day Jugga.
Do a google search for "methanol injection". Will bring up a few pages from the US that sell kits. About $4-500 delivered. You can also make your own with a bit of research.
Will lower EGTs and give a bit more power when set up properly.
Sculls.
401597
