Friday, Jan 29, 2010 at 17:34
Thi is some of the information i've been able to get from this guy that i know that is designing this new Solar Thermal unit.
Through the utilisation of the Phase Change Material (PCM), Energy Storage Units, this product, addresses the issue common to all previous
solar power systems, the diurnal supply of solar energy from the Sun. The PCM Energy Storage Units enable 24hr generation and are designed to handle up to 3 days without sunshine.
If inclement weather persists the dual
fuel micro-turbine can be specified with a fluid or gaseous back-up system.
As all of our systems are capable of paying for themselves and providing an income, the break- even point (BEP), that is never reached with PV systems is reached within 2-3 years.
Solar Concentrator
CSE CSP parabolic concentrators are used to magnify the solar energy and concentrate it on a small receiver area. The reflective loss is about 8% and due to the rigid nature of the stainless steel mirror, the solar radiation is concentrated from 30metres down to 10cm at the thermal collector of the storage capsule.
The stainless steel reflector has a Titanium coating to prevent the build-up of dust or corrosion and is expected to last for 50 years with monthly maintenance.
The design uses a short, squat tower with extended arms to support the thermal energy storage(TES), and MicroTurbine. The concentrator, TES and engine will weigh about 30 tonnes and will present a minimal surface area to high winds when in the
park position (12 noon).
The TES is designed to provide enough energy for 3 days of autonomous generation without solar replenishment after which the unit operates on liquid or gaseous
fuel. Using CNG the exhaust is cleaner than the ambient air with <7ppm NOx at 18% O2.
Fig 1 – CSE CSP Unit
The 65Kw installation will include a 30metre parabolic concentrator. This reflector follows the sun throughout the day with predictive and peak power tracking software.
Phase Change Material (PCM) Energy Storage Unit
The solar energy is concentrated into a 10cm thermal receptor in the base of the Thermal Energy Storage (TES), at up to 2100oC. The Phase Change Material (PCM) is secured in silica carbide envelopes and operates in the latent heat area of the temperature range, 1410oC.
Silica Metalloid stores thermal energy to supply micro-turbines which are connected directly to the storage unit and fed thermal energy via a nitrogen medium.
Silica Metalloid is produced from beach sand in Western Australia. It has a large latent heat storage capacity in the phase change area, 20 times the storage capacity of a lead acid battery. The silica melts at 1410oCelsius and is then heated to 2100oCelsius throughout the day.
After sundown or on cloudy days, this latent energy is used to maintain the operation of the micro-turbine. The system is therefore a base load design with the capacity to produce its rated output 24 hours per day for up to 3 days without sunshine.
During long periods of inclement weather the micro-turbine uses gaseous or liquid
fuel as back-up to guarantee baseload power.
671019
