GQ diesel vibrations
Submitted: Thursday, Oct 02, 2003 at 22:14
ThreadID: 7568 Views:1882 Replies:3 FollowUps:5
Gday guys.I have recintly purchest a 91 GQ patrol diesel whith approximatly 200000 ks on the clock.There seems to be a grating type vibrating noise coming from the gearbox at low revs 600-1000 in all gears.Worst of all in first and second.Could it be bearings or clutch or what?As far as I can tell the vehicle has not been abused,still all standard.Has any one else had similar problems,what ushely goes on these vehicles?
thanks for all the help
GQ42
Reply By: Truckster (Vic) - Thursday, Oct 02, 2003 at 22:36
Get the gearbox serviced first by a proper spanner man, check the oil for metal, and then see how it goes..
AnswerID: 32651
Follow Up By: Fred - Thursday, Oct 02, 2003 at 23:47
How do you service a gear box?? Changing the oil is it apart from dismantling it ....
FollowupID: 23362
Follow Up By: Truckster (Vic) - Friday, Oct 03, 2003 at 10:37
Remove the sump plate and inspect, adjust clutch etc, they can tell him what is fubar more than you or I can tell him.
FollowupID: 23370
Follow Up By: gq42 - Friday, Oct 03, 2003 at 16:10
Thanks Truckster will give it a go and see what happens.
FollowupID: 23385
Reply By: Mike - Friday, Oct 03, 2003 at 01:07
It wouldn't be a GQ if it didn't growl at low revs. Some are noisier than others, but they all growl. It would however be a good idea to change all of the transmission oils if you are not aware when it was last done. An awkward job but you'll save a mint if you can manage it. I think Gregories have a workshop manual for them.Lol.
Mike
GU4.2td
AnswerID: 32662
Follow Up By: gq42 - Friday, Oct 03, 2003 at 16:16
It seems a little worse than others,will change oil and see what gives
thanks
FollowupID: 23387
Reply By: Spanky - Friday, Oct 03, 2003 at 12:47
OH WHAT A FEELING!!!!!!!!
MY NNNNNNIIIIIISSSSSSSSAAAAAAANNNNNNNNN
Go Member Bob
AnswerID: 32684
Follow Up By: Truckster (Vic) - Friday, Oct 03, 2003 at 15:11
Unlike 80 and 100 series owners, who have problems from front diffs blowing, to engines dying, I'd be happy with a noisey gearbox.
FollowupID: 23383
