Sump Plug Washer
Submitted: Thursday, Feb 04, 2010 at 19:17
Michael46
Fibre, Plastic or copper
Not sure what I should use, does anyone have any definative information for a Troopcarrier diesel
Michael
Reply By: Tonyfish#58 - Thursday, Feb 04, 2010 at 19:25
Mine used to have Copper, but I am sure a good fibre washer would be just as good.
402679
Reply By: Lex M (Brisbane) - Thursday, Feb 04, 2010 at 20:26
Copper.
402691
Reply By: Member - MUZBRY(Vic) - Thursday, Feb 04, 2010 at 20:32
Gday
Give me the sizes and i'll make you one of each.
I am not advertising my own wares, i am not associated with myself and will receive no renumeration for said washers.
Murray
402693
Follow Up By: Member - Axle - Thursday, Feb 04, 2010 at 20:41
Murray,
While your at it , Don't forget my air cleaner!!......:)))))))))).
Cheers Axle.
672175
Follow Up By: Member - MUZBRY(Vic) - Friday, Feb 05, 2010 at 15:24
Gday Axle
The size mate,,the size,,cant make without the size
Murray
672335
Reply By: Kanga1 - Thursday, Feb 04, 2010 at 21:23
Hi Michael, my Troopy has the 1HD-FTE motor and Toyota sell me Aluminium sump washers for the engine. Cheers, Kanga1.
402710
Reply By: Member - Phil G (SA) - Thursday, Feb 04, 2010 at 21:24
Toyota sell the fibre washers for the sump - about $1.50 each. I change
mine every 2nd oil change.
For the gearbox, transfer and diffs they use aluminium washers
402711
Follow Up By: Member - MUZBRY(Vic) - Friday, Feb 05, 2010 at 15:27
Gday Phil
I make washers about that size for .06 cents each by the thousands.
Murray
672336
Reply By: The Rambler( W.A.) - Thursday, Feb 04, 2010 at 23:14
Ihave a 2001 Troopy with a copper sumpplug washer which has never been changed and no leaks.
402742
Reply By: That Troopy Bloke (SA) - Thursday, Feb 04, 2010 at 23:35
Mine hasn't had a washer for at least the last 200,000 kms.
A quick wrap with thread tape seals it perfectly.
Glenn
402748
Follow Up By: Roughasguts - Friday, Feb 05, 2010 at 12:49
Yup I do the same, never leaks oil,
well from the drain plugs that is!
672307
Reply By: Member - sdr00y (Beecroft,NSW) - Friday, Feb 05, 2010 at 09:42
I made one from leather from an old pair of shoes. Smooth side away from the sump.
402793
Reply By: signman - Friday, Feb 05, 2010 at 10:34
When I had Troopy- I'd purchase my 10l Valvoline Oil, a Valvoline filter for a tad less than $60 and they'd throw in a couple of fibre washers, a sachet of screenwasher stuff, and a lil bottle of car smelly stuff !!
402801
