Jayco Swan Independant suspension/advice
Submitted: Sunday, Feb 07, 2010 at 11:15
Mr Z
I'm just after a bit more info regarding the Jayco-simplicity independent
suspension.
I believe it has no shocks? if this is the case are there any dampening issues?
Is it worth paying the extra for this system on a Swan?
And same for the ALKO drop jacks, worth the extra?
Also which awnings do you recommend for a swan, the bag awning, the annexe or a roll out awning?
Whichever I get I would like to add walls to it.
I will also add the bed end flys, and maybe a kitchen awning?
My local dealer gave me a leaflet with the various awnings, flys etc. Alpine Annexes in Ringwood/Vic. Do these guys supply Jayco Australia wide? or just Vic, anyone had any experience with them?
so my list so far:
Jayco Swan outback
bag bed end flys
roof rack
12V kit
awning and walls (yet to decide which type)
bumper bar
gas line for bbq
maybe
suspension and drop jacks
For those who have been down this path do you have any other recommendations or advice?
Reply By: PradOz - Sunday, Feb 07, 2010 at 11:42
Hi - after owning the slide in sailtrack type and bagged bed flys I would suggest you have a go at the dealer rolling them back up into the bag. They can be difficult and require patience. No doubt the dealer will say you will get better with experience but unless you roll/unroll these things every weekend they take some time and patience. With this in mind i would not buy a bagged annexe or side awning roof. Reason - its much longer than bed flys and unless you can guarantee that everytime you have to pack up you will have someone holding up the other end and even possibly the centre, how will you get it back up and zipped into the bag without a lot of swearing and cursing. The bed flys can be a pain due to their bulk with the sides on them. Having said that I roll ours back up on my own but it is a slow and very unhappy event. I am happy with the bed flys with sides whenthey are up. They give great privacy in the day and shelter from rain if you want windows open. A roll out type awning roof would be the easiest i think. How it is with annexe walls compared to a normal fitted roof I am not sure. Some say they are noisier.
Look around at after market supply and fitting. Going through a dealer will cost you big time. I have even found that when buying directly off Jayco different outlets have different prices as they may use different suppliers. It does apply to annexes, flys and walls from the calls i have made to them.
The roof rack is only good if you actually use it. If you are not sure leave it and buy it later from Jayco. Easy enough to fit yourself, remember to use silicone in the holes before screwing it on. May even be worthwhile ringing a different Jayco dealer and ask for prices on supply of accessories only. It may surprise you how much your dealer is charging you. You would normally think by buying so much you get a great deal - its not always the case.
The rear bumper could be useful if you need it. I have fitted one myself and apart from mounting a bike rack every now and then it is handy to stand on and also prevents you hitting the van back when pushing it around. (Some including Jayco may say you should not fir a bike rack to the rear.)
What does the 12V kit do? The BBQ line could be handy. A lot of owners
cook outside only and if thats what you do could be worthwhile. However some use different methods of cooking other than a BBQ so will depend on you. Same with drop down jacks. They are probably quick but are they worth the cost to you?
Sounds like this maybe your first van/camper. If thatsthe case i would suggest that what you think is necessary now before using it will be different after you actually gain experience afterwards. With that in mind maybe better buying the absolute essentials and then price the difference in dealer doing and you buying later and fitting all the rest.
Alpine Annexes in Ringwood/Vic do not supply the dealer in
Sydney or Nowra. As I said earlier it is done locally. You can but bed flys direct from Coast to Coast etc. Cheers....
403079
Follow Up By: PradOz - Sunday, Feb 07, 2010 at 11:48
that should be:
FIT a bike rack
and
BUY bed flys ...
grrrrrrrrrrr :/
672568
Follow Up By: pmk03 - Sunday, Feb 07, 2010 at 12:40
We have the bagged awining & bed flys on a Jayco Outback Eagle & find them very easy to use. There is a tirck to it. We leave ours up & pack up the the camper under them (if you know what I mean). After the roof is wound down pull the awning (or bed fly) back over the camper roof, with a person at each end it is easy to roll them up along the roof using the camper roof as a base. My wife uses a small to step ladder to help her reach.
We find if you do it this way you will have no trouble getiing them into the bags & zipping them up.
By the way, the Jayco dealer we went to offered their own bag flys & awning as opposed to the genuine Jayco ones. I think they are much better.
PMK
672581
Follow Up By: Mr Z - Sunday, Feb 07, 2010 at 13:03
Yes this will be our first camper, moving on from years of tents and swags.
We think that with a
young family now, a camper will make life a little easier.
The 12V kit is an onbaord battery and charger, to run lights etc....
672588
Follow Up By: PradOz - Sunday, Feb 07, 2010 at 20:26
Hi again, what year model is the Swan? If its a later model i would have thought it was already 12V, hence my question re 12V kit. If its an earlier model like
mine (1995) its 240V with extra 12V lighting but needs extra 12V system/setup if wanting to
free camp 12V. As its your 1st camper its always good to start off simple and work up to the extras you need that suit your style of
camping. Plenty you can do yourself if you are handy as they are not hard to work on. The Swan is a great layout, plenty of room for a family and everyone can have enough space to keep out of your "hair". The fridge being opposite the door is excellent too. Cheers....
672648
Follow Up By: PradOz - Sunday, Feb 07, 2010 at 20:34
Hi PMK
thanks for
the tip, i will try that next time. Do you do the same thing with the kitchen awning and roll it up on the roof? Also does your flys have the mesh sides? I presume you fold them flat onto the fly after it is spread out onto the roof?
My point re the rolling up the bagged flys and awnings is its much easier as a 2 person job where the slide in flys and awnings can be done on your own if you are
camping by yourself or just with the kids like i have done, cheers....
672651
Follow Up By: pmk03 - Sunday, Feb 07, 2010 at 21:54
Hi PradOz,
Yes. We do the same with the awning too. You just need to make sure you remove the sides from around the upright arms. (the velcro bits) then you can leave the awning set up as you lower the van roof. Then remove the poles & pull it back across the roof
Yes, We do have the fly with the mesh sides. As you suggest we fold them flat while on the roof before rolling it up.
My awning & bed flys are made by Pretige Jayco in
Geelong vic.
PMK
672670
Reply By: kingswoodwagon - Sunday, Feb 07, 2010 at 13:48
I haven't seen any Jayco Camper trailers with Roll Out awnings. I was under the impression the roof/uprights were not sturdy enough to hold the weight. Unless that has changed with the newer models. :) I have seen them on other brands.
We don't have any trouble rolling up both the bag awning and the bag bed end fly's, except its a 2 person job and this can be made difficult if the missus is looking after the kids. We will admit its not our favourite job. If you can, it would be worth putting a Roll out awning on. We also don't use the bed end fly's for 1 or 2 night stops (unless its raining).
Enjoy
403098
Follow Up By: Nomadic Navara - Sunday, Feb 07, 2010 at 15:13
The conventional roll out awnings are not suitable for camper trailers, the arms do not telescope sufficiently to stow the awning for travelling. Anyone fitting a roll out awning to campers use the Aussie Traveller Coolibah
Site Link or the Omnistore types (also available from Aussie Traveller.)
672600
Reply By: garytee - Sunday, Feb 07, 2010 at 14:38
I have had both types of bed-flies and awnings on a Swan and a Dove over 12 years. I prefer the slide-ins everytime.
On my new Dove I had the Alko drop-jacks fitted - brilliant.
403104
Reply By: Kim and Damn Dog - Sunday, Feb 07, 2010 at 18:13
Gidday
I’ve had Fiamma F45 awnings on two camper vans and found them to be very easy to roll out and back in. The latest model is a lot more robust than the earlier units.
I wouldn’t be buying awnings walls at this stage unless you intend staying in the one spot for a week or so (you’ll be surprised how many second hand vans are sold with unused walls).
If you do decide to purchase walls, don’t forget the draught skirt to run along the bottom of the van.
Yes, the drop down jacks are
well worth the extra money.
Here are few other things I'd recommend you consider also (depending on the budget):
1. A roll up jockey wheel.
2. Two 60L
water tanks with a 12V pump. Also have a good quality Flikmaster tap installed
3.
Water tank gauges
4. Hyland articulating hitch
5. Anderson plug to power the 12v system from the car when on the move
6. A Black & Stone gas gauge
7. Lastly, and this happens often, will the camper trailer fit into the car port or the garage?
If you want to discuss the set up further, give me a ring at work on (03) 97055467.
Kim
403133
