Folding SOLAR PANEL damage !!
Submitted: Monday, Feb 08, 2010 at 11:28
signman
I recently acquired a portable 'folding panel' setup. The first thing I noticed was the vulnerability to damage to the glass the way the panels folded- even when in the flimsy nylon bag.
Granted the glass is supposed to withstand a hail stone of a particular size from a particular height- but I could see when unloading from the vehicle or setting up, it would be easy to strike the panel on a sharp corner or edge, smashing the glass and making the thing useless.
So- I reversed the hinging, so the panels close now with glass face-to-face, allowing for a 2mm sandwich of convuluted cardboard between. Refitted to 'hold together' clip and carry handle...and all good !!
Reply By: Wayne (NSW) - Monday, Feb 08, 2010 at 11:52
signman,
Just remember to remove the protective cardboard after setting the solar panels up.
How are the CSR trip preparations going?
Wayne
403237
Reply By: Member - Porl - Monday, Feb 08, 2010 at 12:07
I joined my own.
Drops of silastic on the rims keep apart the glass bits, permanently.
403240
Follow Up By: signman - Monday, Feb 08, 2010 at 12:11
Good thinking- re the cured silicone 'blobs'....
672716
Reply By: Rod E B - Monday, Feb 08, 2010 at 12:10
When I got
mine they were panel face to panel face
403242
Follow Up By: Member - Scoot (SA) - Monday, Feb 08, 2010 at 12:44
Mine was face to face also, makes sense.
672723
Follow Up By: Rod E B - Monday, Feb 08, 2010 at 13:04
Having said that
I made a MDF "box" to hold my panels
it sits in the back of the territory just inside the rear door and I can stack stuff on top of it , more or less it slides in like a draw , with sliders on the bottom of the lower panel
672727
Reply By: Mandrake's Solar Power- Monday, Feb 08, 2010 at 12:18
Just a word to the wise - you probably just voided your warranty .. So I hope for your sake nothing goes wrong with the panels .. :-(
Steve
403245
Follow Up By: Mandrake's Solar Power- Monday, Feb 08, 2010 at 12:50
And I don't think you have gained much as the rear ( underside) is usually the same glass as the top but covered in a white EVA film . So you can still smash it from the underside on a sharp object - you just avoid unnecessary scratches on the solar surface by reversing the panels .
Steve
672725
Follow Up By: signman - Monday, Feb 08, 2010 at 13:15
Agree Steve..however with the panels facing out- the glass is virtually flush with the frame. When reversed at least the vulnerable glass is recessed the thickness of the frame. I guess if I were perdandic I could pop river some perforated aluminium sheet on for full protection !!
672728
Follow Up By: nickoff - Monday, Feb 08, 2010 at 13:40
But if you do that, wouldn't you increase the latent heat potential when out in the sun, and reduce your panel efficiency?
672736
Follow Up By: Mandrake's Solar Power- Monday, Feb 08, 2010 at 13:51
If the protection panel had a small gap at top and bottom of the panel then it might actually improve latent heat disbursability by having a slight cooling effect sucking air in at the base and expelling it at the top .. Simple physics hot air rises .
Maybe you could patent the design signman !!
Steve
672739
Follow Up By: signman - Monday, Feb 08, 2010 at 13:52
Hiya Nick
The perforated sheet we use..is about 80% perferation !!
672740
Follow Up By: Rod E B - Monday, Feb 08, 2010 at 15:58
Mandrake ,
what do you voided your warranty
regards
Unwise one
672752
Follow Up By: Mandrake's Solar Power- Monday, Feb 08, 2010 at 16:16
what do you voided your warranty ???
Not quite sure how to answer that Rod ...
Like to translate for me ..
Steve
672755
Follow Up By: Rod E B - Monday, Feb 08, 2010 at 16:29
sorry left out the word mean
above you said ,
a word to the wise , looks like you have just voided your warranty
what do you mean
672756
Follow Up By: Mandrake's Solar Power- Monday, Feb 08, 2010 at 16:43
Most warranties have an exclusion clause for self-inflicted damage - as I said "probably" this could void any warranty claim because signman has altered and thereby damaged the original goods - So it is possible the warranty has been voided ..
Really depends on how the affect of reversing the panels is accepted or not accepted by the warranty holder ...
Steve
672759
Reply By: Member - Kiwi_In_Aussie(Wagga) - Monday, Feb 08, 2010 at 16:42
Also suggest that with time (for example I mean one trip along the CSR) even the corrugated cardboard will rub against the surface of the panel and 'scuff' it.
I speak from experience :-)
403274
Follow Up By: Mandrake's Solar Power- Monday, Feb 08, 2010 at 19:21
Yes I wondered about that myself - suggest a fabric layer instead of cardboard or even some of that rubbery sheet used to stop things sliding off shelves - Little $2 shops sell it in rolls of 1 metre lengths ..
Steve
672775
Follow Up By: signman - Tuesday, Feb 09, 2010 at 09:42
Thanks for the comment Kiwi
I have noted your suggestion- and did the silicon blobs as recommended by a previous poster. I feel that will be more efficient.
672853
