heater hoses-78 series
Submitted: Monday, Feb 08, 2010 at 18:55
Jimmy88
G'day. I just bought some radiator and heater hoses for a 78 series hzj 4.2L cruiser. I was given a hose which is called 'heater hose outlet No.1'. Can anyone please tell me where this hose is located? Also, is there any other hoses I should stock up on for a big trip.
The other hoses I have bought are:
*The two radiator hoses
*Heater outlet hose
*Heater hose to tap
Is there such a thing as a bypass hose on a landcruiser?
Thanks for you help.
Reply By: Member - Phil G (SA) - Monday, Feb 08, 2010 at 20:02
I think there are three heater hoses - two of which are called bypass hoses. The following diagram might help:
TOYODIY Website.
403306
Follow Up By: Member - Phil G (SA) - Monday, Feb 08, 2010 at 21:10
Actually, on closer look, its 2 hoses and a pipe!
672791
Reply By: Haza - Monday, Feb 08, 2010 at 21:18
I take radiator hoses and for the heater hoses I just carry a foot of hose thats the right size for vechicle heater hose, some hose clamps and teflon tape and a couple of bolts that can fit into the hose. Just saves a little space. I also carry a coulpe of feet of
fuel hose with 4 clamps and 2 couplings.
403319
Reply By: Member - John (Vic) - Monday, Feb 08, 2010 at 22:05
You can buy the whole set of heater and radiator hoses from
Terrain Tamer for not a lot of money.
Which means you are carrying the complete set for all occasions.
403331
Reply By: Member - ross m (WA) - Monday, Feb 08, 2010 at 22:27
The heater hose outlet number 1 is the steel pipe that runs down the RH side of the engine from the front of the head.
if the ends are not corroded ,its probably good.
I think they are called bypass hoses because they still work when the thermostat is closed to get the heater working ;)
403336
