hj47 landcruiser fairey overdrive
Submitted: Wednesday, Feb 10, 2010 at 13:23
Alec L
is it possible to recondition a fairey overdrive that fits to a hj47 landcruiser? if so where? also do they make a noise while working, like a whining noise?
Reply By: Member - Scott M (NSW) - Wednesday, Feb 10, 2010 at 14:31
check out this thread:
overdrive thread
Thought about doing this in my '82 HJ47 but decided against is as:
1. costly
2. new gears need to fit in existing case and are half width gears ... worried about stressing them
3. ever tried to corner a 40 series troopy over 100kph?? - decided the current set up was fast enough for my use...
403617
Follow Up By: Member - Scott M (NSW) - Wednesday, Feb 10, 2010 at 15:05
dozers reply in the link is probably relevant
"The gearmasters havnt been around for long.....they are costly suckers, but probably the best alternative if you have the later 4 speed and transfer in there now....it will last forever, and 5th in a 5 speed is only 15% compared to the gearmaster.....also look at marks4x4.com as they sell the od's// now a negitive for them is gear noise at highway speed....because the diameters of the gears are smaller and larger, there is a trade off in whining of the gear teeth.
The other thing with the gearmasters is low range can be made lower aswell....
673130
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Feb 10, 2010 at 14:34
Alec drop a 5 speed in instead, you can get an adaptor for the transmission brake or put a later model rear end in with the handbrake on the rear brakes.
Some put dyna 5 speed boxes in also.
Dave
403619
