What transfer case oil for an NP205 - effie or oka owners
Submitted: Wednesday, Feb 10, 2010 at 17:29
ThreadID: 75935 Views:3112 Replies:3 FollowUps:0
Hi all,
For those with old effies or Oka's running a cast iron NP205 transfer case, what oil are you running.
Dave
Dave
2015 Fortuner
Had 72 cruisers in my time
Reply By: Peter_n_Margaret - Wednesday, Feb 10, 2010 at 21:17
Unbelievable? No, absolutely TRUE Dave............
Whatever you put in the engine is right for the transfer case.
Those are bullet proof by the way........
OKA196 Motorhome
AnswerID: 403677
Reply By: Member - David G (WA) - Wednesday, Feb 10, 2010 at 21:55
Good day Dave, Peter is quite right but i use Mobil hd 80w90 simply because it handles the heat better when in use in the northern parts of the country and because i have used Mobil gear oils in trucks i have owned with no real problems when worked hard in extreme conditions and with extended service intervals. Just a personal preference. Good luck with the Tojo build cheers Dave
AnswerID: 403691
Reply By: Member - Tour Boy ( Bundy QLD) - Thursday, Feb 11, 2010 at 08:56
Thanks for that,
I was told that I could use anything from an 80w to a 140w and was leaning towards the castrol epx 80w 90 that I usually use as it will be going in the izuzu diffs as well.
Dave
Dave
2015 Fortuner
AnswerID: 403729
