76 series wagon GXL & ARB roofrack
Submitted: Wednesday, Feb 10, 2010 at 18:28
ThreadID: 75937 Views:3157 Replies:1 FollowUps:0
Hi there
I traded in my patrol for 76 GXL wagon and fitted the old ARB rack. However I see that the rear door rubbers foul on the legs of the rack to the point where they do not seal after opening and closing the doors.I was looking to hear from others with the same vehicle and rack as to whether they have this problem.
HK
Reply By: Member - Kevin B1 (WA) - Wednesday, Feb 10, 2010 at 19:29
I have the 76 Series fitted with a Tracklander roof rack and the outer section of the door seal is folded back by the leg bracket when the door is closed. This dose not affect the inner part of the seal that seals against the door frame. If your not sure place the edge of a sheet of paper against the door frame from the inside, shut the door and if the paper is gripped it's sealed if not you have a problem.
AnswerID: 403668
