79 series cruiser gbox noise
Submitted: Thursday, Feb 11, 2010 at 18:49
qubert
i have a small clunk type noise comming from my landcruiser gearbox. it only happens when i put the gearstick in first and then releas the clutch. and it only happens when the oil is hot. its not very consistent though, sometimes its quiet and sometimes its louder and makes the gearstick slightly bump to the left a bit. ( about 10mm measured at the top). has anyone had this type of problem. i am 100% sure its the gearbox and not the diff , transfer case or drive shaft.!
Reply By: Road Warrior - Thursday, Feb 11, 2010 at 19:58
Could it be one of your engine mounts of the gearbox crossmember? If the shifter is moving then the whole gearbox is yes?
403795
Follow Up By: qubert - Thursday, Feb 11, 2010 at 20:07
could be, the movement feels a bit too sudden for that. but someone else actually suggeted that too
673400
Reply By: Troopy(SA) - Thursday, Feb 11, 2010 at 22:06
Could be the intermediate shaft - it's a common problem on the non turbo 78 and 79 series.
I had a similar in-consistent clunk in my 78 series for over 1 year until it finally went - the intermediate shaft stripped and I had no drive at all. Lucky I was only 10 minutes from home. Fix was around $3000 as I had a few other things done at the same time.
403822
Follow Up By: qubert - Saturday, Feb 13, 2010 at 09:12
ok thanks,it is going in to hospital on tuesday so i guess i will find out
673645
