looked in the arcivies last post this subject 2007/8
Submitted: Friday, Feb 12, 2010 at 22:33
Member - Mal B
looking at fitting air bags to my 1992 80 series [2in lift] local Aus made airbag man about $300.00 delevered, coil rite x USA about $175.00 delevered, like to buy local but big diff in cost any help Mal B
Reply By: Member - Barnesy - Friday, Feb 12, 2010 at 23:14
If quality is the same then go local. Better back up service if problems arise, that $125 would be eaten up quickly with the smallest problem.
403978
Follow Up By: Member - Barnesy - Saturday, Feb 13, 2010 at 17:31
My polyairs are fine. No problems at all, make the car a lot more stable when towing.
673727
Reply By: Hunt - Saturday, Feb 13, 2010 at 01:08
Hi Mal B
I have just brought coil rite bags for my 1995 80series from airbag man which cost $275 delivered the next day exceptional
services,thought about buying from usa but decided after briefly talking to the guys here (found them very helpful )to buy local after all my wife keeps reminding me i have wasted more than $100 on lesser things.Fitted them myself in about 4 hours at an easy pace.
Hope this is useful.
Brett
403991
Reply By: Alloy c/t - Saturday, Feb 13, 2010 at 10:56
Go the Firestone coilrights from the USA , [blue ones] higher psi rating than polyairs [ max 100psi compared to 35psi for the poly ] ,, fitting is easy and simple , trick is to read the instructions twice , jack up 1 side of BODY and remove wheel , put airbag into bucket of hot
water to soften , squeeze all air out of bag and put supplied rubber seal over inlet point , the bag will slip inbetween coils of the spring ,saves having to remove spring for fitting , take rubber seal from inlet and bag will expand ,attach hose ect.
404018
Reply By: Member - Royce- Saturday, Feb 13, 2010 at 13:42
brought, ect sigh
404034
Reply By: Member - Mal B - Tuesday, Feb 16, 2010 at 19:48
looks like you cannot buy air bags x USA for any truck that is not standard [ie 2in lift] thanks Mal B.
404457
