12 volt fans
Submitted: Tuesday, Feb 16, 2010 at 16:01
ThreadID: 76064 Views:5909 Replies:5 FollowUps:10
See post 39576----since then has anyone found a cooling fan that puts out a decent amount of air.
My unit has a light truck chasis with 15ft pop top camper, the cabin has no aircon, so I made an evaporative one that fits on front seat between passenger and driver, it does cool the cabin a bit and blows cool air on both of us at the same time.
Have used a car thermo fan , 10 inch that has a guard on it , it uses 6.5 amps , which is okay when driving.
My aux battery is 105 amps and after making this one I could make a larger version for the body but would need lower wattage fan or fans , one thought was the car cooling fans, they seem to to put out a lot of air but never seen one outside the box.
Kitchen exhaust fan with inverter another thought.
Reply By: Atta Boy Luther - Tuesday, Feb 16, 2010 at 16:27
If you are serious then you want the yachties fan .
fan
AnswerID: 404430
Follow Up By: Member - michael H (NSW) - Tuesday, Feb 16, 2010 at 16:34
I will second that
whisper quiet with a low power draw
Cheers Michael
FollowupID: 674124
Follow Up By: Member - Phil G (SA) - Tuesday, Feb 16, 2010 at 16:50
Its $99 at Whitworths
Caframo fan
FollowupID: 674125
Follow Up By: _gmd_pps - Tuesday, Feb 16, 2010 at 16:58
Good advise
I have one in the cabin of my boat. Won't do without
good luck
gmd
FollowupID: 674126
Follow Up By: keviny6 - Tuesday, Feb 16, 2010 at 18:26
thank you all --but no good for use i want
FollowupID: 674135
Reply By: Member - Bruce T (SA) - Tuesday, Feb 16, 2010 at 17:34
Can recommend the Sirocco by Caframo from Whitworths. But it was more than $99.
AnswerID: 404441
Follow Up By: keviny6 - Tuesday, Feb 16, 2010 at 18:28
checked them out yesterday ---no flat one and all have bases----though while i was there bought a water pump $30 cheaper than at caravan place
FollowupID: 674136
Reply By: Robin Miller - Tuesday, Feb 16, 2010 at 17:55
Have a 10 inch 20w cheapie supermarket fan here Kevin.
Run it off my 120w square wave $15 inverter.
Works well , current draw is higher at 36 watts (3 amps) off car battery.
Took the shroud off to make it smaller.
Runs full size 40cm ones well as well.
AnswerID: 404444
Follow Up By: keviny6 - Tuesday, Feb 16, 2010 at 18:25
problem is the fan must fit flat to hole cut in plywood to drag cool air air out of base -- what does yours look like cant have a base either that why i went to car thermo fan
FollowupID: 674133
Follow Up By: Robin Miller - Tuesday, Feb 16, 2010 at 19:03
Your car thermo fan is best in that application Kevin , what you could do is get the biggest you can find and have series resistors for speed (and hence noise control).
You can get blower fans from wreckers but will put out higher noise for same air flow as blades are designed to work in a tunnel so to speak.
My solution is meant to be more portable and is used in the tent etc as well.
While their is plenty of scope to modify the normal house fans , I wouldn't because of the 240vac they run off.
FollowupID: 674139
Reply By: Mandrake's Solar Power- Tuesday, Feb 16, 2010 at 18:25
Couple of these would do the trick - Fans Only draw 0.3A and blow 135 CFM ..
Steve
AnswerID: 404445
Follow Up By: Wok - Tuesday, Feb 16, 2010 at 18:49
I have tried this & the Coolermaster equivalent...they are both low-pressure fans...great inside a tent for sleeping [very quiet]. Unfortunately they were not effective enough in the open[2m distance]. Baffling didn't help much.
eng hoe
FollowupID: 674137
Follow Up By: keviny6 - Tuesday, Feb 16, 2010 at 22:18
not enough CFM though 2 together might
FollowupID: 674170
Reply By: sastra - Wednesday, Feb 17, 2010 at 11:35
Look here.
It's called Endless Breeze and is 12v with 3 speeds and moves a lot of air on slowest speed.
Current draw in specs is pretty accurate. We bought ours from US as couldn't source local. Very good product.
http://www.fantasticvent.com/products/endless_breeze/endless_breeze.html
AnswerID: 404544
Follow Up By: keviny6 - Thursday, Feb 18, 2010 at 15:20
looks like i have to get what i want from usa as well , they have what want, with exchange and posting there other fans are still a lot cheaper.
12 volt gear -----why is it so dear?
FollowupID: 674443
