domsetic fluoro lights off inverter
Submitted: Tuesday, Feb 16, 2010 at 20:39
qubert
has anyone had experience running 240v , 4ft flouro lights from a 240v inverter. just readinf the jaycar catalogue and it seems as though its a bit hit and miss.!!
Reply By: GerryP - Tuesday, Feb 16, 2010 at 20:59
Hi qubert,
Haven't tried it, but possibly the starting circuitry requires a proper sine wave, especially if it has some form of electronics in it - just a thought.
However, I did pick up a Redarc 12V fluoro starter which replaces all of the 240 V stuff and allows a normal household tube to run from a 12V supply. I fitted it to a standard 20 watt (2 ft) light fitting and it works beautifully - instant start and
bright as! They will run both 20 and 40 watt tubes.
Not sure of the price (I got it from someone else) but see
here for details on the Redarc site.
Gerry
404470
Follow Up By: GerryP - Tuesday, Feb 16, 2010 at 21:02
Just checked the prices.
$65 for 20 watt & just under $75 for the 40 watt. Might be a tad pricey, but they do work extremely
Gerry
674156
Reply By: qubert - Tuesday, Feb 16, 2010 at 21:09
will have a look
404472
Reply By: Member - Allan B (QLD) - Tuesday, Feb 16, 2010 at 21:14
My son runs a pair of standard 36W batten fluros from a 150W square wave inverter quite successfully. Only modification required was to disconnect the power factor correction capacitors. The inverter did not like them.
404473
Reply By: Member - William B (The Shire) - Tuesday, Feb 16, 2010 at 21:25
Hi qubert,
the other day I was given a 65 ah deep cycle battery, I charged it over night and thought would see if I could run a set of flouros I have off my 300 watt inverter.
So, equipment went as follows,
65 ah deep cycle battery, 2 years old,charged for 12 hours
a flouro light with 2 x 2 foot 18 watt globes, standard starters.
a tricky dicky 300 watt modified sine wave inverter.
to my surprise the lights fired up straight away and put out a very
bright light for 4 hours before I turned off the light to go to bed.
by memory the voltage stayed over 12 volts the whole time.
I was very pleasantly surprised, both by the fact the battery I was given seemed to be a good one and the fact the inverter and lights worked so
Hope that helps,
William
404478
Reply By: Member - Christopher P (NSW) - Wednesday, Feb 17, 2010 at 13:49
Hi All, i have run twin batten 1200mm long fluro's off my tricky dicky 300watt inverter, my gmc 800watt genny with out a problem. the tricky dicky inverter has a 450-600 watt start up function from memory which will handle most loads.
404558
Reply By: StormyKnight - Wednesday, Feb 17, 2010 at 19:04
If your inverter is a pure sine wave one then you will have no troubles. Pure sine wave is identical to the power from a normal power point.
Cheaper
inverters are square wave or modified square wave. The power correction devices in the fluro are designed for a pure sine wave, with a suare wave inverter these power correctors will be taking a fair proportion of the supplied power meaning the fluro as a whole becomes less efficient. It also means that you will have to have an inverter that can supply more power than simply the summed ratings of the fluros.
You can get 12V fluros, perhaps that is an option?
404600
Reply By: kiwicol1 - Wednesday, Feb 17, 2010 at 20:19
Have never been able to understand why so much light is needed when
camping.
col
404615
Follow Up By: Bob of KAOS - Thursday, Feb 18, 2010 at 07:22
Just
camp under a street light and get free illumination of the night sky ;-)
674360
Follow Up By: qubert - Thursday, Feb 18, 2010 at 19:05
ha..me too, luckily i am not
camping ey ....doophus
674481
