Landcruiser rims onto Hilux?
Submitted: Wednesday, Feb 17, 2010 at 17:18
portlester
Hi guys
Hopefully a simple questions with a quick answer ... (but then again)
I'm selling some rims & tyres that have come off my recently purchased Trak Shak. They are King steel rims 16x7 & currently have 265/70R16 tyres on them (not that that will help to work this out). They are 6 stud and Landcruiser/Patrol offset.
I've had an enquiry asking if they will fit a 92 model Hilux surf/4runner.
My quick search of the net hasn't come up with anything definitive. Does anyone have an answer for this one?
Reply By: Member - Tour Boy ( Bundy QLD) - Wednesday, Feb 17, 2010 at 17:52
sometimes the nissan offset will scrape on the front caliper of the hilux. Toyota studs are the same but not the offset. The cruiser offset will fit the hilux.
If you aren't sure, fit to the front tighten the nuts and spin the wheel or take it for a drive and check the inside for scrape marks.
Dave
404579
Follow Up By: portlester - Wednesday, Feb 17, 2010 at 18:40
Thanks Dave
I didn't want to say 'Yes' they would fit and they don't, nor say 'No', lose the sale and then find out that they did fit.
Ian
674277
Follow Up By: baldman - Sunday, Feb 21, 2010 at 09:47
The landcruiser offset should fit the Hilux without any issues, most of the guys on the surf
forum run the cruiser rims with the favourites being the 15x8 rims as they widen the stance due to the offset -22offset
The patrol rims also fit, however the issue is the patrol hub centres ane slightly larger so there is more stress on the wheel studs when fitted to the hilux platform.
However the best option as with all
forum advice is get down to a tyre dealer and ask them. Just pretend your buyiong new for your car and they will confirm all the info you need.
674872
Reply By: charlie brown - Wednesday, Feb 17, 2010 at 19:08
hi portlester
i had early 80 series steel rims on my 04 hilux see photo in my profile to see if they are the same
404605
