landcruiser engine swap
Submitted: Sunday, Oct 05, 2003 at 10:50
ThreadID: 7610 Views:12396 Replies:5 FollowUps:3
what diesel engine conversion would you recommend for my 1978 hj45 pickup ute. this vehicle came with the "H" engine not the "2H" engine that began in 1980. the cruiser has the stock 4 speed and transfer case. was thinking about a V8 diesel also a 1HZ diesel. don't mind a complete drivetrain swap, engine, trans, and transfer case. would also like disc brakes at all 4 wheels. any ideas? bad experiences, any info would be appreciated as well as info on who to speak with on this project. regards, robert
Reply By: Truckster (Vic) - Sunday, Oct 05, 2003 at 17:58
V8 Chev Diesel Turbo.
Brilliant engine, and lots o neddies.
AnswerID: 32824
Reply By: ross - Sunday, Oct 05, 2003 at 18:55
I got to be honest ,I once thought the GM V8 diesel was great being a chev fan,until I come across some american sites.This engine is actually a big block chev V8 that has been dieselised and comes in 3-4 different capacities.It is fitted to the chev/holden suburban and to the famous hummer.In the US they have had so much trouble with them that many GM dealers refuse to stock diesel vehicles unless ordered.The US defence forces have a deal with GM every time a unit breaks down it is replaced under warranty with a brand new one regardless of the problem so that is where all these 2nd hand units are coming from as well from dealers.To be fair most of the problems are not with the actual motor,but the Stanadyne injector pump that is fitted .There is also cyl head cracking issues as well that allow water into the combustion chamber.There are thousands and thousands of complaints from customers who had the pump replaced 3/4/5 times and are still not satisfied. GM have being having problems with their car diesels going back to the early 80s.This has caused a consumer backlash against diesels inthe US partly because of that and the fact that US consumers are far less educated on diesels than Australians and Europeans who have had wonderful service from diesel powered vehicles going back decades.It has upset companies like Mercedes that have complained that Americans think that diesels are all the same as GMs .Now I know some have had good service out of their 6.2/6.5ltr but overall the engine has an unenviable record of failure and thats coming from a chev man.
Do a search for" Diesel Doctor" a US forum that attempts to help owners with concerns about all diesel motors but is snowed under with with just one motor.
AnswerID: 32831
Follow Up By: ross - Sunday, Oct 05, 2003 at 18:57
I would recommend you go the 1HZ if that is feasable.I also think keeping it all Toyata would attract a fairer resale price when it is time to sell.
FollowupID: 23469
Reply By: Rob from Cairns Offroad Training & Tours - Monday, Oct 06, 2003 at 08:42
Give the old girl a tidy up and put it on the market. Then buy exactly what you want second hand. Much less stress and agravation.Cairns Offroad Training & Tours
AnswerID: 32859
Follow Up By: robert4615 - Monday, Oct 06, 2003 at 11:16
rob, thanks for the good input. what you said is exactly what my wife says. maybe now i can talk her in to a brand new 79 series with factory diff locks. now what engine would you recommend for complete reliability. thanks robert
FollowupID: 23506
Reply By: Member - Peter [SA] - Monday, Oct 06, 2003 at 11:24
Toyot have brand new, ready to go 1HZ motors for $6900.00 at the moment. Normally about $12000.00
AnswerID: 32866
Reply By: Member - DOZER- Monday, Oct 06, 2003 at 13:20
Gday
Diffs from a 78 series will fit in easily with 4wdiscs. If you bought a writeoff, it would most certainly come with a 1hz/5 speed that will go in fairly easily aswell.
If not your preferance, keep an eye out for a 12ht from a turbo 60 series, it should go straight in being a 2h block, same again if you buy a writeoff, you may get the 5 speed aswell plus wiring harnesses etc. This is the cheapest way to retrofit as you can make your $$ back from spares. Check out www.pickles.com.au
Andrewwheredayathinkwer mike?
AnswerID: 32876
Follow Up By: robert4615 - Monday, Oct 06, 2003 at 14:03
peter, thanks for the info. where can i purchase the 1HZ diesels at this price? tel#'s ,websites, any info will be appreciated. regards, robert
FollowupID: 23513
