Iphone reception on Next G in rural areas.
Submitted: Thursday, Feb 18, 2010 at 09:51
ThreadID: 76114 Views:8873 Replies:7 FollowUps:3
I currently have a 6120 which is great in the bush, especially with the force cradle and patch external antenna. ( usual post search etc)
I am thinking of going to a Iphone 3Gs and wonder if anyone has experience in the following.
1)How does it's 850mhz reception compare to say the 6120?
2)Has anyone used the Bury technologies cradle that has a patch antenna, and does it work at 850mhz?
3)Can you use it to connect a PC to the internet via bluetooth?
Thanks in advance
Reply By: chisel - Thursday, Feb 18, 2010 at 10:12
1) My wife had a 6120 and I had an iphone for a while, both with telstra. We did a bit of touring around qld last year and found them fairly similar in coverage. I was expecting the 6120 to be a lot better but it wasn't significantly better. We did not have a cradle.
3) You can certainly use the iphone as a modem via a usb connection. It works quite well and is easy to setup. I'm not certain about bluetooth. Best place to look for advice is the whirlpool iphone forumhttp://forums.whirlpool.net.au/forum/128?&p=1
I'd like to hear of experiences with cradles/antennas for the iphone.
AnswerID: 404709
Reply By: Gone Bush (WA) - Thursday, Feb 18, 2010 at 10:48
Apple calls it Internet Tethering:
Site Link
I bought the Cellnet inductive cradle and patch lead but haven't used it yet. Inductive is all that's available.
There's a recent thread on all this somewhere.
AnswerID: 404717
Follow Up By: Gone Bush (WA) - Thursday, Feb 18, 2010 at 10:53
Here it is:
Thread 74791
FollowupID: 674386
Follow Up By: Member - Boobook - Thursday, Feb 18, 2010 at 11:01
Ahh thanks Gone Bush :-)
Looks good re the tethering.
Thre are varied reports in the reception though.
FollowupID: 674387
Reply By: TerraFirma - Thursday, Feb 18, 2010 at 11:15
I would say the Iphone 3GS is good in rural areas, I have had enough reception to get an SMS through when other phones couldn't. I'm not sure that the inductive antenna would help a lot. I also have a Telstra 165i Rural phone with pull up antenna and patch capability, it is the emergency phone if you like and only cost around $150 on Ebay 2nd hand, I have a long life pre paid Next G sim sitting in it so I don't have to swap simms from the Iphone, so far so could haven't had to use it yet, however going 150KM's offshore next week and plan to test them both
AnswerID: 404721
Reply By: Member - Graham H (QLD) - Thursday, Feb 18, 2010 at 13:27
Here goes The Iphone is not as good as a 6120 by a long shot.
My wife is using my 6120 since I got the Iphone and can have several bars when the Iphone has only 1.
Make sure the Iphone has NEXT G enabled more battery usage but better reception
I have a Carcomm cradle with an inductive aerial and this makes a significant difference to both phones.
Get the Carcomm here
http://www.ow.com.au/shop/iPhone-Car-Accessories-Car-kit-holders/Carcomm-Apple-iPhone-3G-In-Car-Mobile-Phone-Cradle
Cost $129 + $10 post
It works on all frequencies as its the aerial not the cradle that makes the difference
I have an RFI multiband aerial which works on 850-900-1900-2100mhz
So will pick up anything that available Cost $129 at a Telstra shop Dont pay more some are dearer
Basically the Iphone is a City phone as thats where the yuppies are.
Force and Kressell now make leather cases with a spring clip for the Iphone as well
Got a force at Target for about $10
AnswerID: 404748
Reply By: Bob of KAOS - Thursday, Feb 18, 2010 at 13:43
I've just ordered the Apple iPhone 3G S Bury Comfort Car Kit with External Antenna which is $89.90 including postage.
I'll let you know how it goes.
Unfortunately, data with Telstra is fiendishly expensive. $59 a month for 1 GB datapack on the phone. The same 1 GB is $39 if you use a wireless modem - go figure!
God help you if you go over the limit.
Even thats outrageous compared with other providers. 1 GB from 3 is $15 a month (including the USB modem).
Its hard to know what to do. I use the Telstra SIM card in the satphone, and have to pull it out and put it in the iPhone for local calls and using the phone as a modem. I could get a separate 1GB plan for the modem, which will mean an extra 1 GB data, and no more swapping SIM cards - is it worth $40 a month?
I hate Telstra.
AnswerID: 404749
Follow Up By: Member - Carl- Saturday, Feb 20, 2010 at 17:46
We find reception about the same as a telstra country phone.
We also found that on a I phone you can use 1 GB very quickly and the over use rates are pretty high. We moved to a 5 GB use plan for $89 amonth.
You will be impressed with all the capabilities of the new Iphone. We even use our as a compass.
FollowupID: 674777
Reply By: DesF - Thursday, Feb 18, 2010 at 20:03
Hi I have been using the 6120 for 2 years as a modem on the laptop, no extra ariel, works all over australia ( where we have been ), only have used it in townsmostly but works great anywhere you have a signal ( most places) .
Mate used the same setup on his trip and I was talking to him on Skype at Undara Lava Tubes.
It has bluetooth as well but I find it quicker to just plug in the cable and open Nokia PC suit , and you are on in 10 seconds.
I just have a data pack from Bigpond the $10.00 for 150 meg seem s ample for normal use when travelling.
Cheers Des.
ps, just got the new 6720 seems good connects the same way,
AnswerID: 404800
Reply By: Bob of KAOS - Friday, Mar 05, 2010 at 06:50
Boobook
The Bury cradle arrived yd.
It is a very well made unit, and the phone connects easily and securely.
I have an iPhone 3G. In the cradle I get 4 bars, out of the cradle 3 bars (in the driveway at home). The antenna is a dipole about 15 cm long that sticks to the windscreen. Its on a 2.5m cable. With the phone cradled and charging there is no access for an extra USB cable so tethering has to be via Bluetooth. Its a pity they don't put a USB port on the cradle.
I can't find the specific frequencies covered but as it is designed specifically for the 3G I am certain it covers frequencies relevant to the phone.
Bury brochure.
It matches the cradle I have for the satphone, which has proven to be robust and effective.
At $79.95 USD its looking like a bargain.
AnswerID: 407318
