Toyota 2H front seal replacement.
Submitted: Wednesday, Feb 24, 2010 at 15:50
ThreadID: 76296 Views:6739 Replies:5 FollowUps:1
My 60 series 2H diesel is in need of a new front oil seal. Can anybody tell me the socket size required to get the front pulley nut off?
My Gregory's doesn't say, and as it's my daily drive, I need to know I have a socket before I start. :)
Radiator and shroud are still in there now, so it is impossible to get in and check it out at present.
Any special tips for the job?
Reply By: Member - William H (WA) - Wednesday, Feb 24, 2010 at 18:38
Try a 46mm socket wrench
AnswerID: 405787
Reply By: Member - ross m (WA) - Wednesday, Feb 24, 2010 at 18:56
When I had to do a similar job,I went out and bought a $7 set of calipers for moments like these.
You might be abe to do it with the radiator in place but remove the shroud.
I use the starter motor with the extension bar against the ground to loosen the nut. : )
AnswerID: 405790
Reply By: Member - Serendipity(WA) - Wednesday, Feb 24, 2010 at 19:33
William is correct - 46mm
Image Could Not Be Found
AnswerID: 405794
Reply By: Member - G N (VIC) - Wednesday, Feb 24, 2010 at 20:04
Hey Cruiserman
Not sure if this is correct advise but i would consider applying some locktite to thread, say #243 as well as being SURE to retension to Toyota specs!
I have seen 3 of these come off while driving over the years and one buggered the end of the crank shaft!
Best of luck GN
AnswerID: 405797
Reply By: Cruiserman - Wednesday, Feb 24, 2010 at 20:39
Thanks to you all!
46mm it is.
And thanks Serendipity for the pictures.
AnswerID: 405807
Follow Up By: Member - William H (WA) - Wednesday, Feb 24, 2010 at 20:51
and don't skin your knuckles....doing the job.also on the pulley shaft have a look and see if it has worn a groove..where the older seal was working on it.
FollowupID: 675526
