LC80 transfer case front output shaft bearing
Submitted: Wednesday, Feb 24, 2010 at 16:20
ThreadID: 76297 Views:2198 Replies:2 FollowUps:0
The front OP Shaft bearing on my 80 is a little noisy. I replaced the oil with a heavier weight 80w/140 and it went quiet.
Now the question isdo I have to remove the case to replace it or can it be done with the case still in the car?
The rear OP bearing seems fine. When I turn it by hand it is smooth however the front one has a rattly feel to it.
Also, is there any harm in running the heavier grade oil?
Thanks,
ROb
Reply By: Top Ender - Wednesday, Feb 24, 2010 at 16:34
It can, but it is a PITA.
AnswerID: 405772
Reply By: Member - Rob S (NSW) - Wednesday, Feb 24, 2010 at 19:03
Hi Rob
It's not hard to remove the transfer case from the gearbox in the vehicle.
As for just removing the front out put shaft haven't tried that yet.
The rear out put can be done in the vehicle.
Rob
I only ever made one mistake
AnswerID: 405792
